EVENTS
Check in for status!
Jump over to the
Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Forums50
Topics121,369
Posts977,717
Members44,215
Most Online1,229 Jan 21st, 2020
 Plumbing issue
OP
back yard wrench turner
I know there are many knowledgeable people here. I am looking for a solution to stop water flowing after a set time period.
Yesterday I had a toilet overflow because the flapper hung up on the chain. It ran for 3 hours and filled the septic tank then overflowed into the bathroom. Luckily we got home before any water escaped the bathroom.
I've found automatic flow stops that have sensors that will detect water that has overflowed. What I would like to find is a device that will only let water flow for a set period like 1 minute.
Does anyone know if this is available?
Wayne When I die, I hope she doesn't sell everything for what I told her I paid for it! 1938 1-Ton Farm TruckIn the Stovebolt Gallery [ stovebolt.com] Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. malmwayne@hotmail.com
 Re: Plumbing issue
Is there a way to incorporate an overflow setup for the septic system for when it gets too high to prevent the water from backing up into the house?
 Re: Plumbing issue
Boltergeist
I don't know of anything available commercially, but it would be fairly simple to wire a timer and a solenoid valve that would shut off water flow to the float valve in the toilet after a preset time. A microswitch on the flush handle would start the timer, which could then be set to shut the supply line off after whatever time it's set for. Jerry
The murder victim was drowned in a bathtub full of Rice Krispies and milk. The coroner blamed the crime on a cereal killer! Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
 Re: Plumbing issue
The last toilet valve I bought has a feature that stops the water from flowing when something sticks. I have no idea how it works but it does work. I got it at Ace. Edit: I just went and looked. It's the Korky 528.
 Re: Plumbing issue
OP
Further interweb search turns this up: https://www.amazon.com/Water-Block-Excess-Shutoff-Valve/dp/B074V9LL19#customerReviewsIt says adjustable from 1 gallon to 13 gallons. Tiny, the Korky site doesn't show that valve to shut off the water supply line unless the tank is to the fill point. My issue was with an open flapper.
 Re: Plumbing issue
Wayne, rather than putting a band-aid on the problem, why don't you just fix the toilet? It doesn't take much ($ or time) to replace all the innards of the toilet tank and get it working like it should. Or you could get one of the new-fangled pressure assist low flush toilets that use 1.6 gal per flush.
My dad owned a plumbing shop and we made lots of calls to fix the toilets of the "jiggle the handle" crowd. Pretty easy homeowner fix.
Kevin First car '29 Ford Special Coupe #2 - '29 Ford pickup restored from the ground up. Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] Busting rust since the mid-60's
 Re: Plumbing issue
My issue was with an open flapper. Exactly it's saved my bacon a few times for that very problem, open flapper. "Designed to fix no/slow refilling, running, and noisy toilets"
 Re: Plumbing issue
ODSS Lawman
I agree. Fix the toilet, new flow master, flapper, done. $30 in parts.
Now as for the septic, I would suggest an alarm system that alerts you well before the tank reaches overflow. It’s a simple float system that can be wired to a light, alarm, or even a system that can email you.
SWEET Sergeant At Arms Old Dominion Stovebolt Society BUNS?!?!?! Where we're going, we don't need no buns..... 1950 GMC 450 (25% owner)1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery [ stovebolt.com]
 Re: Plumbing issue
OP
Yep, it's right to replace the innards. Kinda light the battery in my car, when it stutters, I replace it. Usually last about 5 years. The toilet is at least 8 years old. However I'm also thinking about other possibilities for water leaks and wood floors, cabinets, drywall etc.
For what my insurance deductible is, I could put the safety backup in my house. It would also possibly cause a reduction in my homeowners insurance.
The septic overflowed from the toilet not shutting the water off.
 Re: Plumbing issue
It seems to me you need to have your septic tank pumped. Around here they are 500 to 1000 gallons.
