The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
19 members (Achipmunk, 60ApacheC20, D B Cooper, DennisM, Brian_Ostner, Bill Trotter), 126 guests, and 3 robots.
Forums50
Topics120,545
Posts966,246
Members43,693
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Dash Layout - Ignition Switch Location??
#1366467 Fri Jun 26 2020 12:00 AM
Started the rewiring in my 49 3600 and realized I never was sure how the ignition switch is actually supposed to mount? The bracket in the picture, when I got the truck, was just on the floor and the ignition switch was hanging by its wires.
I've seen pictures that show the switch in different locations; I had installed it in that hole above where I'm holding the bracket and it fits fine. But what is right, and if the switch does go in the bracket, what goes in that big hole in the dash?? There is also a small hole in that bracket - I read somewhere a light goes there?
Any information on that is appreciated! Thanks
1949 Chevrolet 3/4 Ton - Still Solid.
Re: Dash Layout - Ignition Switch Location??
NorthCoast3800 #1366478 Fri Jun 26 2020 01:54 AM
Jim Carter shows this
kevinski 1954 GMC 9300 Welcome to the virtual Garage
NorthCoast3800 #1366482 Fri Jun 26 2020 02:13 AM
Interesting... that curve doesn't match the curve of the dash which throws me too (it's the reverse curve - meaning that can't fit flush, or even bolt up, in that position)
Also doesn't explain what would then fill the hole in the dash? Unless maybe someone drilled that hole after - quite possible. I've seen photos of these trucks with the ignition in both that bracket, and in the dash.
NorthCoast3800 #1366486 Fri Jun 26 2020 02:33 AM
Bracket fits under dash with switch sticking through hole in dash. If you look under side of dash beneath ignition switch hole you will see 2 holes for mounting bolts
1949 gmc 1-ton
NorthCoast3800 #1366487 Fri Jun 26 2020 02:37 AM
Maybe I should say behind dash. Rounded part of bracket will match rounded part of dash small hole in bracket for light socket
1949 gmc 1-ton
Johnny N #1366496 Fri Jun 26 2020 04:04 AM
Ahhhhhhh OK thank you!!! That starts making sense smile
NorthCoast3800 #1366550 Fri Jun 26 2020 05:44 PM
DADS50 #1366566 Fri Jun 26 2020 06:56 PM
Moderated by  ndkid275
