The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (Cosmo, BlueMule, Ed Blouch, 55_2nd_Series, 1953 panel, Dajja, 2 invisible), 203 guests, and 3 robots.
Forums50
Topics120,585
Posts966,535
Members43,706
Most Online1,229
Jan 21st, 2020
Image Posting Policy
AC R45S Spark Plug
#1365969 Mon Jun 22 2020 06:15 PM
dougs Offline OP
Has anyone used a AC R45S spark plug on a 1955 235 engine and what is the advantage over a regular R45 Plug?
Re: AC R45S Spark Plug
dougs #1365972 Mon Jun 22 2020 06:35 PM
Boltergeist
Be careful- - - - -I believe the "S" stands for "short". The threads of the plug aren't long enough to fully engage the female threads in the head, resulting in the bottom threads being exposed to combustion gases. They will get clogged with carbon, or possibly get burned away by the heat of the combustion chamber.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
dougs #1365977 Mon Jun 22 2020 07:47 PM
The S in the AC plug number stipulates a projected tip. This was used to prevent fuel fouling at low speeds and also to cool the spark plug at higher speeds.
Thread length is the same between the 2.
BC
1960 Chevy C10 driver 235 T5 3.73 dana 44
1960 C60 pasture art
G.M dealer tech since 1980 & counting
dougs #1365981 Mon Jun 22 2020 08:51 PM
I agree with BC. It is a much better plug then the older stile. They are for o-head valve engines only.
George
1956 Chevy 1/2-Ton Pickup
dougs #1365988 Mon Jun 22 2020 09:28 PM
ace skiver
Here are images of different AC Delco "R45" spark plugs:
R45
R45S
R45TS
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Moderated by  Justhorsenround
