The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (classicchevs), 162 guests, and 3 robots.
Forums50
Topics120,922
Posts969,326
Members43,791
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Removing Pitman Arm from St. Box.
#1365625 Fri Jun 19 2020 09:25 PM
ronusny Offline OP
Anybody have any ideas for separating pitman arm from box?
I tried:
- Gear puller
- Banging the dang thing.
- Propane torch.
Ron A
Re: Removing Pitman Arm from St. Box.
ronusny #1365629 Fri Jun 19 2020 10:08 PM
Boltergeist
There is a very heavy duty puller called- - - -wait for it- - - -a "Pitman Arm Puller"! The splined, tapered shaft on the steering gear, and the corresponding splined taper on the arm form a very tight fit. I usually use a 3/4" drive impact wrench on the puller. A lot of them actually have a couple of bolts that keep the puller jaws from spreading out and slipping off. Some auto parts stores will rent that type of tool, with a big security deposit.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
ronusny #1365630 Fri Jun 19 2020 10:12 PM
I have also used a fork type device between the arm and case, careful on the case.
Ed
ronusny #1365634 Fri Jun 19 2020 10:18 PM
ace skiver
I have used
this [shop.advanceautoparts.com] and this [amazon.com].
No problems with either device.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
ronusny #1365658 Sat Jun 20 2020 12:12 AM
I used the very same type tool Tim refers to in his post. It worked like a charm on my 1954 3604 (3/4 ton) truck.
Ronnie
1954 Chevy 3604 - A work in progress...
" You can't keep dancing with the Devil and wonder why you're still in hell"
ronusny #1365697 Sat Jun 20 2020 01:52 PM
I'd let you borrow my pitman arm puller, if you lived a little closer. You should have no problem finding one locally.
Craig's '50 Chevy 3100 5 window
My truck
If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
Moderated by  Justhorsenround
