The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 members (), 195 guests, and 2 robots.
Forums50
Topics119,951
Posts960,604
Members43,521
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Valve cover bling
#1365339 Wed Jun 17 2020 11:40 PM
37 GC Offline OP
My 1937 GC has a 39 216 and I was reluctant to post these pictures for fear of extreme jealousy! Seriously, has anyone seen these vintage add-ons to help the old girl breathe better? They are stamped with patent pending (wonder how that went?) Soldered or leaded into place and stuffed full of Brillo pad like steel wool. Creativity at its best.
All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
Re: Valve cover bling
37 GC #1365345 Thu Jun 18 2020 12:23 AM
Very cool! Never seen anything like them.
Mike
37 GC #1365350 Thu Jun 18 2020 12:48 AM
big_eek Looks like their imagination got carried away.
Mistaking the valve cover for a missile slicing the air!
Those look better than NACA scoops on an airplane!
#valve cover envy
'59 Chevy Suburban, NAPCO
37 GC #1365353 Thu Jun 18 2020 01:27 AM
Boltergeist
Those covers look cool, but I'm going to guess they will actually hinder, not help the crankcase ventilation. The air blast from the fan will create a low pressure area behind the add-on covers that will probably cancel out the vacuum created by the airflow past the end of the road draft tube. There will be little, if any flow from the valve cover, through the crankcase, and out of the draft tube like is supposed to happen.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
37 GC #1365403 Thu Jun 18 2020 12:24 PM
I'm with Jerry on that idea. Maybe if you mount them the other way so the fan pushes air into them?
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
37 GC #1365420 Thu Jun 18 2020 02:39 PM
Boltergeist
Installing a PCV valve in place of the road draft tube might be the best solution.
37 GC #1365482 Thu Jun 18 2020 09:40 PM
37 GC Offline OP
they are installed facing the firewall so not an issue. they did not open the tops beyond the factory slits, must've just been for looks and bragging rights "mine are bigger"!
37 GC #1365486 Thu Jun 18 2020 10:39 PM
Jack of all Trades, Master of None
If you reversed them, the fan might make positive pressure in the engine. That probably won’t help keeping the oil in the crankcase.
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Moderated by  Woogeroo
