The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (ASU, Montana 54 Chevy), 108 guests, and 3 robots.
Forums50
Topics120,505
Posts965,905
Members43,690
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
transmission oil
#1365003 Mon Jun 15 2020 07:01 PM
I'm getting ready to finally take this thing for it's first drive in 50 years. The shop manual calls for 160w in the tranny.
What is everyone using in theirs?
Re: transmission oil
'37 barn find #1365007 Mon Jun 15 2020 07:55 PM
ace skiver
1937 Chevrolet Truck transmission oil specifications [chevy.oldcarmanualproject.com]
Are you asking about the weight/grade, or the brand?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
tclederman #1365011 Mon Jun 15 2020 09:12 PM
weight and type.
'37 barn find #1365027 Mon Jun 15 2020 11:26 PM
I think it is time to reassess the oil you are thinking of using . The spec/additives for oil over 80 years ago was quite different to todays product .
My experience has been 80,000 miles of daily use , original 1940 , 4spd (non-syncro) with new bearings in it 22 years ago.
I was advised by a friend who was workshop manager for a road construction company that they used a Castrol GP50 engine oil (rated at 90 gear rating) for their old trucks ,
I have found the cold running gear changes easy and smooth , hot running just the same , I often carry the trucks full load (camper) and the g/box is still as quiet as you would like .
(just look at those beautiful 80 year old gears smile )
Dusty #1365040 Tue Jun 16 2020 12:27 AM
Those are some fine looking gears for sure. It's funny what we admire in our old age.
Oil is certainly much changed and improved so I'm trying to find out what everyone is using these days.
'37 barn find #1365153 Tue Jun 16 2020 07:32 PM
Y
yar Offline
'37 barn find,
Lubriplate makes the exact oil you are looking for, their SPO-288. I found it available in quarts at WBC Industrial in Colorado Springs and I've been using it for many years in my '36 Chevy pickup that I've had since 1965. With the Lubriplate product the '36 transmission shifts much better than it did with any parts store gear oil and better than with so called "600W" oil offered by so many vendors. Interestingly that "600W" stuff isn't even gear oil. It's steam cylinder oil.
Ray W
Ray
'37 barn find #1365181 Tue Jun 16 2020 10:29 PM
'37, another good option today is one of the GL4-rated gearbox-specific oils. They are brass/bronze component and synchro-friendly, and have the right slipperiness (coefficient of friction) to promote smooth shifts, regardless if the transmission uses any "yellow metal" or not. GL5 gear oil designed for use in hypoid rear end assemblies is not recommended, as it is corrosive to brass/bronze (for transmissions that have that material) and may not have the correct coefficient of friction to promote smooth shifting.
I use Red Line Oil's MT90, since Red Line products are what I have in my shop for several newer vehicles I service. The Red Line products have been known to improve shifting in particularly balky vintage BMW transmissions, FWIW. There are other brand choices for GL-4 gear oils, so ignore the sales pitch, but here is a good white paper from Red Line discussing Manual Transmission Fluids [redlineoil.com]. Note, the MTL that is mentioned is really too low in viscosity for the older transmissions, but the MT90 is fine.
'37 barn find #1365241 Wed Jun 17 2020 12:06 PM
Thanks, I'll try that.
This is my first project and I have a lot to learn.
Apparently things have come a long way since plain old 90w.
A while back I posted about the leak in the back of this tranny and was going to drill
out what I thought was a frost plug. Was advised that it was a shaft not a frost plug.
I got it cleaned well and sealed with Permatex and that solved the problem. That
advice saved me from ruining the transmission.
'37 barn find #1365258 Wed Jun 17 2020 02:26 PM
The idea that GL-5, and to a lesser degree GL-4 oils are corrosive does not seem correct. That would mean they were effecting the yellow metals even when sitting in storage. The best information I could find about the effects of the additives in GL-4/5 oils is this ;
In normal operation, the sulfur/phosphorous additive forms a black sacrificial coating on the gears and anything it touches with a little pressure and temperature. As the gears turn, instead of wearing, the sacrificial coating of additives is peeled off or worn off. This is normal and acceptable in all steel gears. But when one or more of the surfaces is brass or another soft metal, the sacrificial coating is stronger than the base metal, and instead of just peeling off, it takes with it a few microns of brass that it is bound to.
I have no expertise in this area but it would seem to me that the only time these oils can have a negative effect is during shifting. Perhaps that is why Novak, a generally acknowledged expert in SM420 transmissions says GL-5 is fine in these transmissions.
I will probably never put enough miles on my truck for this to become an issue but to use a phrase I have come to dislike, using "an abundance of caution" I am probably going to drain my GL-5 and replace it with something not known to cause problems.
'37 barn find #1365262 Wed Jun 17 2020 02:34 PM
Y
yar Offline
Good morning guys.
Here's an interesting discussion of the topic:
https://www.fordbarn.com/forum/showthread.php?t=219484&showall=1#:~:text=GL4%20and%20GL5%20both%20contain,will%20destroy%20the%20yellow%20metal.
Lubrication engineers have told me that the GL5 potential adverse effects on yellow metals can only occur at elevated temperatures (250-300* F) that do not exist in ordinary car and truck applications. So the question becomes whether to believe educated professional lubrication engineers or "anecdotal" opinions.
Ray W
Ray
Page 1 of 2 1 2
Moderated by  SWEET
