The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (Flatblu4748, 55 SHAKER, 3B, DennisM, Joe H, Donf, 2 invisible), 220 guests, and 3 robots.
Forums50
Topics122,131
Posts979,681
Members44,158
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Just thinking, 1950 1 ton panel with 1968 K20 running gear?
#1364964 Mon Jun 15 2020 12:03 PM
57NAPCO Offline OP
Hello all, my panel is just sitting in the shop (and has been for 20 something years) waiting on me to do something with it. I have pondered the conversion to a 4X4, off an on over the years but never wanted to take on such a job. Has anyone here done this type of job? If I remember correctly the drive train needs to come from K20 or K30, 68-72 years because the differentials are not as wide as the square body’s and thus won’t stick out from the fender wells and look like hell.
Just curious about your thoughts, thanks.
Rob
..."some gave all, KIA"...
Re: Just thinking, 1950 1 ton panel with 1968 K20 running gear?
57NAPCO #1364972 Mon Jun 15 2020 01:19 PM
57NAPCO Offline OP
This is another one of my “different” rigs cool
1973 El Coolmino, 1970 blazer running gear (Not a frame swap) 383 stroker, turbo 350. Built outside of Salem Oregon, over 30 Years ago. A very proper fab job. I’ve owned it a couple years.
[img]https://i.postimg.cc/k43BM5Qg/6-B742158-19-E0-4-E98-B1-FB-8-A94-CF0-A76-A0.jpg[/img]
57NAPCO #1365035 Tue Jun 16 2020 12:09 AM
Measure your front axle spring perch width. Starting in 55.2 through '91 all the chevy and gmc spring perch widths were 31.5-32".
If I'm not mistaken, the front axlle spring perch width on an AD truck is 26" or something like that because of the taper in the front frame and springs. All that to say, you probably won't find a bolt in Chevy axle unless it's an early NAPCO axle for AD trucks, and those aren't too easy to come by.
I've thought about this swap before for a '52 3100, and I was going to look into the wagoneer dana 44's. They are pretty narrow, and I think they would fit the truck pretty well, but I never went far with that idea, so I don't know how well they would fit.
'66 c10 rust bucket, 350 nv4500 stock bellhousing, '85 c30 front suspension, h072 rear axle with 3/4 ton rear coil springs
'67 cj5 225 oddfire motor, time for disc brake conversion, offset rear dana 44, intermediate pedals and steering upgrade
'48 3804 frame and bed + '52 6400 cab and front clip + 4bt, need to put them together
57NAPCO #1365148 Tue Jun 16 2020 07:17 PM
57NAPCO Offline OP
Thanks ! I’ll be crawling around under it next time I’m at the shop
Moderated by  SWEET
