The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 members (), 244 guests, and 2 robots.
Forums50
Topics120,060
Posts961,569
Members43,548
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Suposebly a 292. Mad at myself.
#1364699 Sat Jun 13 2020 01:36 AM
I am mad at myself and the person I bought the engine from. I was told it was a 292 but a fellow forum member informed me it was not what I thought it was. So could someone help me trying to tell me what inline 6 I have. The number by distributor is CL9601592. Also I want to add a automatic transmission and what flexplate would I need? Thank for your help I added a couple of pictures the engine. Hopefully I did it correctly. If not I will try to load pictures of the engine
UBBCode
Re: Suposebly a 292. Mad at myself.
Asahi1234 #1364714 Sat Jun 13 2020 03:29 AM
Could be 194, 230, 250. Pushrod cover on 292's is about 6" tall, side engine mounts are offset.
Ed
Asahi1234 #1364733 Sat Jun 13 2020 11:01 AM
Unrepentant VW Lover
We need the casting code as shown in the picture below. Then we can tell you. Don't be mad yet ... smile If you can give us the date code, too, great. The engine casting code will tell us. It is a raised number and will look like the example in the second image/attachment.
The engine in the picture is a 261, but the codes might be in the same place on those more modern engines. You might have to clean some crud off to read them.
"There is a life about to start
When tomorrow comes..."
'49 Chevrolet 3804
Asahi1234 #1364741 Sat Jun 13 2020 01:07 PM
Most likely a 250 with a HEI distributor from '75 or newer engine. All 250's are basically the same, all heads interchange and keep the same compression ratio. The 230 uses the same block casting numbers, so look down the spark plug holes to see if it has dish or flat top pistons. 230's have flat top, you can also measure the stroke, 230 has shorter stroke. Both use the same heads.
John Milliman #1364814 Sat Jun 13 2020 10:27 PM
Here are numbers on passenger lower side 5743015 and E2769. These are the only other numbers I found on the block.
UBBCode
Asahi1234 #1364821 Sat Jun 13 2020 11:41 PM
Shop Clutterist
5743015 is supposed to be a 230 block from 1963 - 1970 according to this:
http://www.guiaautomotrizcr.com/images/Aeraid%20head%20and%20block%20manual.pdf
Didn't know that GM was making blocks in Mexico back then...
Gord
1954 1/2 ton 235 4 speed
Asahi1234 #1364944 Mon Jun 15 2020 03:59 AM
The location of the fuel pump on a 292 is center of the block.
"A house is built with boards and beams,a home is built with love and dreams"
Look deep before you leep !!!
"Everything is Everything"
"If I say a mouse can pull a house,Hitch him up"
My 1951 3100 Chevrolet
My 1951 Chevrolet Suburban Carryall
Asahi1234 #1365019 Mon Jun 15 2020 10:39 PM
It has the HEI with external coil. If that is the original ign. system it is 75-77 250 engine.
George
1956 Chevy 1/2-Ton Pickup
Asahi1234 #1365076 Tue Jun 16 2020 04:19 AM
9
Yes 250 of some year? Short side covers dead give away
Karl j Townsend
Moderated by  Woogeroo
