The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 members (WE b OLD, Dusty, D B Cooper, Monsonmotors), 186 guests, and 3 robots.
Forums50
Topics120,565
Posts966,370
Members43,701
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Fuel line filter
#1364808 Sat Jun 13 2020 09:38 PM
I am installing a electric fuel pump on the old truck (59 with a 235 . Was wondering if a inline filter should be between the tank and pump or pump and carb. This does not have the glass sight filter at the carb. Was thinking of one of the steel/alum filters with the replaceable filter.Pump is close to tank.
Re: Fuel line filter
59chevy36 #1364840 Sun Jun 14 2020 02:42 AM
I'd want to catch the trash before it went into the pump...
What electric pump are you using? The one I have on my fire engine is a Faucet and I've had good success with them, but I still carry and NIB pump with me at all times.
I rigged the electric connections at the pump with pull apart connectors and have the new pump with a connector already installed making on the road replacement fast and easy. They will ALL fail at some point...
Why aren't you using the mechanical pump on the 235?
Mike B smile
59chevy36 #1364884 Sun Jun 14 2020 05:37 PM
I have a faucet cube pump. works good just thought a filter would keep the rust/crud outa the carb. The orig pump was gone when i got the truck but it had a electric from a car hooked up but badly. so i mounted a cube pump back by the pass door on the frame . Now am replacing the tank and thought this would be good idea. on your pump does it have a pressure shutoff? mine does not and some times overwhelms the needle valve.
59chevy36 #1364885 Sun Jun 14 2020 05:49 PM
59',
If period-correctness isn't a concern, I like to use Holley regulator 12-804 (adjustable 1-4 psi), which is relatively inexpensive and works well with electric fuel pump setups, and would solve your "flooding" issue. With this type of setup, a small mechanical fuel pressure gauge near the carb is nice to have, and there is an extra port on the Holley regulator that can be used for one.
Doug
59chevy36 #1364887 Sun Jun 14 2020 06:01 PM
The pump I use has an internal pressure relief system to prevent pressure when it's not running.
https://www.pegasusautoracing.com/p...tF9iF88oXJfaiV4MD8sOIEL9IwBoC3MoQAvD_BwE
Mike B smile
Moderated by  Justhorsenround
