The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (capnduane, jorb, olezippi, Rusty Rod, Brad Allen, 1 invisible), 177 guests, and 3 robots.
Forums50
Topics120,964
Posts969,728
Members43,804
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 685 of 697 1 2 683 684 685 686 687 696 697
Re: What did you get done on your bolt today????
GMJager #1364050 Mon Jun 08 2020 09:04 PM
Originally Posted by GMJager
Realized the middle running board mount is bent - have to figure out how to fix that... Its bent up slightly (so its higher than the rest) as well as bent forward... no clue how it happened.
Someone likely backed over a big rock. frown I have 2 that are so bent they need replacing, the others can be straightened. Find a piece of pipe large enough to fit over the mount to use as a pry bar. Put a jack under the inside edge and pry it back down and toward the rear. You shouldn't need any heat.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
BIG CHEVY 3600 #1364224 Tue Jun 09 2020 10:49 PM
Attached front hood emblem, one of the most difficult jobs yet ( gasket not right), feels like 111 degree temp. 99% humidity in Central Florida. Doc
Currently making 1954 3100 better than new
BIG CHEVY 3600 #1364313 Wed Jun 10 2020 01:15 PM
Unrepentant VW Lover
Alvin -- my 15 minutes for next week will be a redo of the pbrake adjustment ... wink Apparently, I need to take out a little more slack.
"There is a life about to start
When tomorrow comes..."
'49 Chevrolet 3804
BIG CHEVY 3600 #1364401 Thu Jun 11 2020 02:48 AM
new running boards, laying under the truck and cutting off all those old rusty bolts wasnt that bad but man was I dirty, trouble is the Boards came from one place and the hardware from another so hopefully the bolts well get here tomarrow, good chance to run it up to the car wash and power wash as much as I could before a layer of under coat
woof359 Family 1952 3100 5 Window
BIG CHEVY 3600 #1364443 Thu Jun 11 2020 01:19 PM
Made the huge mistake of letting 54-3100 set for 6 weeks without starting. xc#xYgtr alcohol in gas. everything is new, tank,lines a perfectly rebuilt model"B" and runs like a sewing machine. Glass fuel bowl has tablespoon of water. This is Florida so all my work starts again, little 54 runs awful. Going to drive 16 miles to a WAWA and get white gas (no alcohol), Only going to use WAWA blue pump gas in everything built before 1972. Dang. Just to make this ol guy happy call your local WAWA and ask for a blue pump. Thats what I did today. Doc
BIG CHEVY 3600 #1364449 Thu Jun 11 2020 01:48 PM
Doc, I have been running non alcohol fuels since I finished my 53.Sometimes it is 4 bucks a gallon here but worth it.
1953 Chevrolet 3100
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
1964 GMC 1000
BIG CHEVY 3600 #1364451 Thu Jun 11 2020 01:56 PM
Doc, I have found the humidity here in Florida contributes to the moisture in gas. I'm also a big fan of non-ethanol gas from WA WA.
I use it in my small motors also. It doesn't seem to go bad like the corn fuel.
Wayne
1938 1-Ton Farm Truck
Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. malmwayne@hotmail.com
BIG CHEVY 3600 #1364849 Sun Jun 14 2020 11:16 AM
I changed the rear differential fluid and adjusted the rear brakes. While under the truck I noticed the rear pinion seal has started to leak, so that job will be added to the list.
porsche #1364913 Sun Jun 14 2020 10:48 PM
I need to do that as well... ever done it so i e been putting it off
BIG CHEVY 3600 #1364925 Mon Jun 15 2020 01:12 AM
Adjusted the front brakes and went for a 33 mile test ride. All was good.
Moderated by  Justhorsenround
