WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Forums58
Topics121,926
Posts983,130
Members44,343
Most Online1,229 Jan 21st, 2020
 1942-46 Rear Window in 1941 Chev Truck?
OP
I have a question about retrofitting a 1942 to 1946 rear window and gasket to replace the window, gasket and zinc molding on a 1941 Chevrolet AK Truck. We have a damaged zinc molding and want to retrofit the later style to this earlier truck. Has anyone had experience with this kind of retrofit. We believe the opening in the sheet metal is the same for all 1941 to 1946 Chevrolet trucks, but have no way of knowing if that is really the case.
Any input from people who know these trucks well will be appreciated. Thanks in advance....Charles Evans
Charles M Evans
 Re: 1942-46 Rear Window in 1941 Chev Truck?
THE LATER GASKET WORKS FINE. DID ONE NO LEAKS RON
Cab sheet metal is not the same, however you may be able to make it work. '41 trucks have lots of parts different than 42-46. best of luck
