The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (49nut, Gulfsuper, DennisM, Dusty53, Hotrod Lincoln, 3B), 149 guests, and 3 robots.
Forums50
Topics120,544
Posts966,241
Members43,693
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Raybestos or AC delco?
#1363366 Wed Jun 03 2020 06:19 PM
Tony292 Offline OP
So I found a brake master cylinder leak and found two options on rock auto. One is a raybestos the other ACDelco. They each have exactly the same picture, raybestos is 100 and ac delco is 139.
Recommendations?
This is for a 1940 1.5 ton WB.
Re: Raybestos or AC delco?
Tony292 #1363369 Wed Jun 03 2020 06:34 PM
General Purpose
Least expensive one. Without a doubt. A new rubber seal kit also works. Rockauto RAYBESTOS MK33 $19. Lifetime warranty.
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
Tony292 #1363370 Wed Jun 03 2020 06:35 PM
Probably both made off shore anyway. Take the cheaper one
1949 gmc 1-ton
Tony292 #1363508 Thu Jun 04 2020 08:13 PM
Boltergeist
It's most likely the same casting, just a different name on the box. "AC Delco" is an offshore brand now, and has been for several years. "Delco Remy" was a division of General Motors that made electrical parts back in the 50's and 60's, possibly as late as the 1970's. I don't think they ever made brake parts.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Tony292 #1363520 Thu Jun 04 2020 09:24 PM
Rebuild it and when you do, hone it carefully and well using brake fluid to lubricate the honing stones. Polish the bore if you are able. That leak will stop unless rust and age have pitted your bore too far. I've seen some that leaked like that out of the box.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Tony292 #1363546 Fri Jun 05 2020 12:43 AM
Boltergeist
Somebody with a lathe and a little common sense can bore and sleeve your original master cylinder with a piece of stainless steel tubing, and it will out live you, and possibly your grandkids.
Moderated by  SWEET
