EVENTS
Check in for status!
Jump over to the
Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Forums50
Topics121,355
Posts977,517
Members44,208
Most Online1,229 Jan 21st, 2020
 glass top fuel pumps
OP
Looks like there is a shortage of glass top fuel pumps. Classicparts.com stopped listing them altogether.
 Re: glass top fuel pumps
I have changed the glass top from a bad pump to a new pump that has a metal top. Six bolts and it's done. Have not run into any problems so far.
Ed
OP
I am getting ready to do that myself if I can find the old glass top pump stashed in my empire somewhere.
They are also on “wait list” at the Filling Station parts.
Check your local FLAPS. O’Reillys or NAPA might still have them. I got one not too long ago.
Thanks guys, I have my 54-3100 restored to 100% pure stock. I have the original and thanks to Ed now I will have a back up. Ed
Currently making 1954 3100 better than new
Shop Clutterist
Are the glass top pumps rebuild-able? Are kits available?
Gord ---- 1954 1/2 ton 235 4 speed
Gord, yes, and yes. I've used kits from Hal Houghton, good quality, and very nice components, but the rebuild process is not for the faint of heart. His kits require the rebuilder to disassemble, reassemble and stake the diaphragm pull-rod assembly. Not hard, but takes a bit of skill. Other kits have the diaphragm and its pull-rod pre-assembled, but I don't know the quality for comparison. His kits are E10-compatible, and pump specific, so he matches the kit by pump number. He has kits for pumps with or without the secondary vacuum wiper-assist stage. Here's his website: Fuel Pump Kits [ classicpreservation.com]
Shop Clutterist
Perfect. That sounds like the way to go.
I"ve thought about finding an OEM fuel pump myself, for when my cheap aftermarket pump dies. Do you know who supplies these? Is a rebuild of similar difficulty to a carburetor?
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
