The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (J Lucas, Dajja, 55 SHAKER, Cosmo, Barnfind49, 5 Window 9434), 220 guests, and 3 robots.
Forums50
Topics120,586
Posts966,534
Members43,706
Most Online1,229
Jan 21st, 2020
Image Posting Policy
65 C60 upper radiator hose
#1362506 Thu May 28 2020 11:31 PM
I want to replace the upper radiator hose on my 65 C60 with V8 350. Would a hose for a 65 C10 pickup be the same hose? I can find those easily. Thanks.
Re: 65 C60 upper radiator hose
Case_man #1362543 Fri May 29 2020 03:47 AM
J M Offline
The best way I know would to measure the id of the hose ends and the length of the hose. If it is a molded hose take it to your local parts store and see if they can match it up. If it has a 350 in it I Don't believe that is the original engine.
Good luck
Jim
Case_man #1362572 Fri May 29 2020 11:34 AM
1969 was the first year for the 350 in the big trucks. Might see if one of the other V8 engines fits.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
Case_man #1362576 Fri May 29 2020 11:49 AM
Thanks for the responses. It had a 327 but I traded that engine for a 4 bolt main 350 a few years ago. I still have the same upper hose on there. It's getting dried out and I need to replace it soon. Yes I'll be taking it off and to the parts store. I was thinking this might be the same as the half tons but that engine might sit down farther from the radiator. I'll take the hose in and see what they can get me.
Case_man #1362579 Fri May 29 2020 12:30 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
The parts stores in my area will let you go behind the counter to find a match if nothing shows up in the catalog.šŸ›
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
Case_man #1362689 Sat May 30 2020 02:01 AM
Yes here to. I have a flex hose that will be here in the morning. I will see how it fits. The radiator end measures 1 3/4" but the engine end is around 1 1/2". The old hose tightened down on the smaller end with no leaks. And this fitting on the engine end came off that 327 so it's what came on the truck. I hope this new hose fits. If not I might have to get a shorter hose and come up with an adapter.
Case_man #1362705 Sat May 30 2020 03:45 AM
You could put in a piece of metal (steel, copper, sst, etc.) and two short hoses. My '69 Tilt cab T50 came that way from the factory. The metal pipe can be any shape you want and any size on the ends. I would suggest a longish hose on at least one end to give it more movement. I don't have a good picture showing mine but I know it is original, the truck only had 4600 miles when I got it.
Mac :{)
Case_man #1362717 Sat May 30 2020 11:00 AM
7
On my Low Cab Forward I ended up getting a hose with the correct diameter and using part of it, cutting it to get to the radius section that fit.
1957 Chevrolet 5700 LCF 283 SM420 single speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto
Case_man #1362789 Sat May 30 2020 07:44 PM
Thanks for the ideas and info. I went back this morning after seeing that I needed to adapt 1 1/2" to 1 3/4". I could tell it wasn't going to clamp down tight like the old hose. After looking in a book they ordered a flex hose with 1 1/2" on one end and 1 3/4" on the other.
Moderated by  69Cuda, Grigg
