The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (Twin Jimmys, MiraclePieCo, ASU, TPR57C, 1 invisible), 178 guests, and 3 robots.
Forums50
Topics121,365
Posts977,668
Members44,213
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Panel Gas Tank Removal Tips
#1362387 Thu May 28 2020 06:33 AM
Today, my son and I were planning to install a new fuel gauge sender for an eventual install of some New Vintage gauges on his '52 1/2 ton panel. We got the tank partially out but the filler neck on the tank got hung up on the frame. Does anyone have any tips for getting the gas tank out of a 1/2 ton panel? It looked like if I removed the driveshaft it would give more movement away from the frame and allow for the neck to clear the frame. We put everything back together with no leaks but now it won't start. (Heading over to the HiPo forum for help with that.) Thanks in advance.
It's a small world, but I wouldn't want to paint it.
Re: Panel Gas Tank Removal Tips
Rusty Shackleford #1362394 Thu May 28 2020 09:25 AM
I think you answered your own question :-)
1949 Chevy Panel Truck
Rusty Shackleford #1362442 Thu May 28 2020 03:44 PM
Are you trying to remove the tank with the filler neck attached?
Loosen the clamps on the rubber hose in between the filler neck and the neck of the tank.
It should drop out without the filler neck attached, mine will on my 1951 suburban.
Tim
"A house is built with boards and beams,a home is built with love and dreams"
Look deep before you leep !!!
"Everything is Everything"
"If I say a mouse can pull a house,Hitch him up"
My 1951 3100 Chevrolet
My 1951 Chevrolet Suburban Carryall
Rusty Shackleford #1362444 Thu May 28 2020 03:57 PM
Tim, I disconnected the filler neck from the tank.
Moderated by  tclederman
