The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (Smangy, TerenceandMary), 102 guests, and 2 robots.
Forums50
Topics120,522
Posts966,059
Members43,692
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: 1939 (VC) 1.5 ton truck. 158-1/2" WB -Front Prop Shaft...
Philipj #1362325 Wed May 27 2020 11:17 PM
Philipj Offline OP
Hello Ed,
I understand from your previous post that you have several torque tube sections... Can you part with one? I am planning to keep the original engine, drivetrain and bolt pattern on the truck...
Philippe Jeanneau
Philipj #1362375 Thu May 28 2020 03:35 AM
Philip,
I do not have any torque tube sections, sorry.
Ed
Philipj #1362424 Thu May 28 2020 01:36 PM
Philipj Offline OP
Thanks for looking....
Philippe Jeanneau
Philipj #1362577 Fri May 29 2020 12:00 PM
That is an odd driveline. While not impossible, it would be very difficult to source a "bolt-in" torque tube rear axle that matches the wheelbase of your project truck. I hope you're parts hunting skills are exceptional! It may be much easier to source an open driveshaft style rear axle and transmission as it would allow a much greater latitude in wheelbase options. I believe that the more readily available 1941-46 deco 1 1/2 ton trucks should be suitable parts donors for your model.
Philipj #1362589 Fri May 29 2020 01:52 PM
Philipj Offline OP
I'm not sure what you mean by odd driveline... Are the 158-1/2" trucks that rare? I'm just after the front section of the torque tube... Yes, ideally I would swap to open drive, the problem is finding the parts either as a whole or or individually... It would make more sense just to swap axles and the rear transmission cover and be done with it, provided the location of the center bearing is the same as the closed driveline...
Philippe Jeanneau
Page 2 of 2 1 2
Moderated by  SWEET
