The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (1866yellowboy, 32vsnake, Hotrod Lincoln, Justhorsenround, FAST55, 1 invisible), 266 guests, and 3 robots.
Forums60
Topics123,449
Posts996,249
Members44,670
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 4 1 2 3 4
Re: 59 C60 Wrecker
VEW #1361565 Sat May 23 2020 12:49 AM
V
VEW Offline OP
Thanks Jerry and Rich. All good advice I will follow.
I’ve never worked on freeing up an engine before and since it’s not mine I don’t want to make a boo-boo.
Glenn-you know I’d love to have you here! I’ve got plenty to work on, as you know, but when someone asks for my help with something, it goes to the top of the priority list. I can always get back to my stuff later.
Victor
41 3/4 Ton Pick Up (in process)
55 Grumman Kurbside (Doughboy) 235/3 on tree w/ OD
57 3100
58 C4400 Viking (Thor)
59 C4500 Short Bus (Magic Bus)
59 G3800 1 Ton Dually (Chief)
Re: 59 C60 Wrecker
VEW #1361654 Sun May 24 2020 01:18 AM
V
VEW Offline OP
I was pleasantly surprised when I removed the valve cover this morning. Not as bad as I was expecting. There's hope!!
Everything is filled with ATF/Diesel. I'll go out in a couple days and see what happens.
Victor
57 3100
Re: 59 C60 Wrecker
VEW #1361662 Sun May 24 2020 01:57 AM
Don't forget to liberally pour some engine oil down each push rod to lube the lifters and cam as it runs by...
Mike B smile
Re: 59 C60 Wrecker
VEW #1361798 Sun May 24 2020 09:38 PM
llikely to break the ringlands if you get too rough with it ...marvel is good medicine dont rush it soak daily !
Re: 59 C60 Wrecker
VEW #1361822 Mon May 25 2020 12:32 AM
V
VEW Offline OP
Got my wife’s toothbrush this morning and took the ATF/D solution to the rocker arm assembly.
Also poured oil down pushrods.
Will see if it will move in a couple days.
Victor
57 3100
Re: 59 C60 Wrecker
VEW #1361859 Mon May 25 2020 11:21 AM
She is not going to like that.
HB
1966 Chevrolet K-10
Flappy Fenders
In the Stovebolt Gallery [stovebolt.com]
More pictures on Photobucket [s160.photobucket.com]
1962 Chevrolet C10
1962 Suburban
Re: 59 C60 Wrecker
VEW #1361867 Mon May 25 2020 02:28 PM
KROIL is expensive, but it works when other concoctions fail. It's also manufactured about 65 miles from where I live in middle Tennessee, so I can usually pick it up without any shipping or hazmat charges!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: 59 C60 Wrecker
VEW #1361887 Mon May 25 2020 04:17 PM
V
VEW Offline OP
Hambone, I have a feeling you might know why, right??
Jerry, you know I'm a cheap a$$. I really like Kroil, so much that I use it up quickly. I figured I would try this way and if it doesn't work, I'll get some Kroil.
May try moving the flywheel tomorrow or Wednesday.
Victor
57 3100
Re: 59 C60 Wrecker
VEW #1361888 Mon May 25 2020 04:23 PM
I've found it's more economical to buy a gallon of the stuff, and use a hand-pumped squirt can to apply it. The aerosol cans busticate the budget quickly, even the "extra volume" ones they brag about! Since KROIL has a habit of creeping through the seams of a metal can, I store it in glass Mason jars once it gets delivered.
Re: 59 C60 Wrecker
VEW #1362492 Thu May 28 2020 09:35 PM
Make it a little easier on yourself and pull all the plugs before you start trying to rotate the engine.
Mike
Page 2 of 4 1 2 3 4
Moderated by  69Cuda, Grigg
