The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 members (bsarts, Hambone, Johnny N, 1 invisible), 112 guests, and 3 robots.
Forums50
Topics119,015
Posts952,752
Members43,313
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: 216 engine squeak
ndkid275 #1361513 Fri May 22 2020 07:03 PM
Jack of all Trades, Master of None
I bought a 5/8” alternator pulley from Speedway and it works perfect. I think they offer other sizes too.
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
ndkid275 #1361520 Fri May 22 2020 07:44 PM
If the belt was bottoming out on that pulley, one needs one size narrower pulley.
Ed
EdPruss #1361524 Fri May 22 2020 08:11 PM
ace skiver
Ed
Or, a wider belt?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
ndkid275 #1361563 Sat May 23 2020 12:39 AM
I have a heavy duty belt that is slightly wider. I’m trying that first since I already had it.
Doc.Hall #1361574 Sat May 23 2020 02:26 AM
Boltergeist
I was referring to the color casehardening process where parts are buried in an airtight crucible full of ground bone chips and powdered charcoal, and heated to 1400 degrees in a ceramic kiln or a forge. Once the proper temperature is reached, the contents of the crucible are dumped into a vat of water. The resulting finish has a rainbow of colors, and a thin layer of surface hardening. That process is considered to be the "period-correct" method of treating hand forged and/or cast steel parts for antique firearms like the 1873 Winchester lever actions, etc. For small parts, I use a 2" diameter pipe nipple filled with charcoal powder and ground bone with a cap threaded onto both ends, and bury it in the coals of my forge for a few hours, then unscrew the caps with channel lock pliers and dump the contents into the water bath. I swap phone numbers and email addresses by PM frequently- - - -no problems yet!
Edit: Here's the process I use:
https://vimeo.com/352941868
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
ndkid275 #1361575 Sat May 23 2020 02:40 AM
Boltergeist
What width belt are you using? If you want to fix the one you've got, remove if from the alternator, use a bolt, a nut, and a couple of washers to mount it in a drill press, and use the edge of a big file to deepen the gullet of the pulley. It will take a little time, and the job would go faster with a lathe, but even a hand drill motor clamped in a vise will suffice to spin the pulley if you don't have access to a drill press. Don't touch the sides of the pulley sheaves- - - -just deepen the bottom a little.
ndkid275 #1361658 Sun May 24 2020 01:34 AM
I was listed as a heavy duty belt for my truck... very minimal change, but might be enough.
Page 2 of 2 1 2
Moderated by  Woogeroo
