The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (drdoug, clarsen3100, Dongray, cmayna, 37 GC, DJMTruck), 206 guests, and 3 robots.
Forums50
Topics120,579
Posts966,468
Members43,704
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: 235 headers
rad #1360085 Wed May 13 2020 05:54 AM
I have tried both water heat and exhaust heat from the fentons to my standard intake manifold .
The water heat took much longer to achieve effective heat and was ultimately cooler than the exhaust heat . I have ended up using exhaust heat . The truck ran like crap with no intake heat at all .
The truck runs great with the fentons , slight adjustment to the carb (metering rod height) wee tweek on the timing smile smile
Re: 235 headers
rad #1361372 Thu May 21 2020 11:06 PM
Never forget the "chicks dig it" factor and remember that polished parts are more aerodynamic. Both add HP.
Re: 235 headers
rad #1361396 Fri May 22 2020 02:30 AM
I have had a chick or two pretend to dig my shiny parts, but I am nearly certain they had other nefarious intentions.
Re: 235 headers
52Carl #1361438 Fri May 22 2020 12:27 PM
Unrepentant VW Lover
What species were these chicks?
nanner
"There is a life about to start
When tomorrow comes..."
'49 Chevrolet 3804
Re: 235 headers
rad #1361448 Fri May 22 2020 01:19 PM
Rad
I agree with Martin, it's your truck, build it the way you want.
But you can learn alot reading and asking questions on this site.
Off topic: Ignore the two thread stealing hoodlums that just posted, they can't help it.
Also, I see that you have Grafton as your location. I assume that is Grafton Illinois.
If so, check out the Heartland Bolters once in a while. It's about time to liven that area up in preparation for the Stovebolt Reunion.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/forums/68/1/the-heartland.html
There are plenty of bolters around St. Louis.
Don
"The Flag Pole"
In the Stovebolt Gallery [stovebolt.com]
More pix on Photobucket [s893.photobucket.com]
'46 2-Ton grain truck
'48 3/4-ton grain truck
'50 2-ton flatbed
'54 Pontiac Straight Eight
'70 American LaFrance pumper fire truck.
Re: 235 headers
rad #1361474 Fri May 22 2020 03:31 PM
Personally, I understand that most engines don't operate in the RPM range to make efficient use of headers, but you have to admit they sound great. I say use the headers, you get always change back once you find the right manifold.
Craig
Come,Bleed or Blister somethings got to give!!!
Q:"What yah runnin"
A:"3/8 drive Black and Decker aquarium pump motor" (the movie HOTROD)
59' Apache 31, long term project (30 years and counting)
Re: 235 headers
rad #1361491 Fri May 22 2020 05:05 PM
If you had enough room, a tuned length will help, but it's probably close to 50" for the primary to get the RPM down.
The siamese exhaust ports confuse the whole thing, there are 2 "extra" reflections in the 2-3 and 4-5 tubes.
Page 2 of 2 1 2
Moderated by  KCMongo
