The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (46forme, dgrinnan, NJC, Justhorsenround, 49shep, 1 invisible), 240 guests, and 3 robots.
Forums50
Topics119,912
Posts960,375
Members43,513
Most Online1,229
Jan 21st, 2020
Image Posting Policy
67-72 half ton questions
#1361148 Wed May 20 2020 06:09 PM
I
Like the title says, I'm picking up a 67-72 2 wheel drive half ton truck and the RF just has a spindle. The truck is 200 miles away from me and 80 miles from anything that resembles a parts store. No hub/rotor or whatever the correct term is for drum brakes. My local parts store was no help. Also where the truck is located there is a 67-72 3/4 ton 2 wheel drive truck I can pull parts off of.
Quickest, easiest thing I think would be the hub/rotor off of the 3/4 to make it roll on the trailer. Does anyone know if the bearings etc will fit to put a tire on to roll on the trailer?
Next best plan is if anyone knows of another junkyard hub/rotor that will fit to roll it?
Last not so good plan is skid it on the trailer as is with wood or old tires under it.
Any other ideas to help get it to the house?
I tried to do pics but no luck for me.
Re: 67-72 half ton questions
IBenDcars #1361153 Wed May 20 2020 07:05 PM
IBenDcars
Likely a difference between 67-70 C10 front spindles and 71-72 spindles as the earlier had drum brakes and later had disc brakes. Need to know year for gathering parts.
I would consider a car dolly to haul it. Get front end on dolly, strap it down & head home. Very doubtful the 3/4 ton stuff will fit the C10.
delky dave in WYO
1957, 3100, v8
1990 Suburban
IBenDcars #1361155 Wed May 20 2020 07:30 PM
I
LF has a drum brake, so 67 to 70 them.
I don't have a car dolly. Hoping to get it on a regular trailer for the 200 miles home
IBenDcars #1361156 Wed May 20 2020 07:35 PM
General Purpose
Skid or build a skate.,,,,,,,or a piece of plywood with a pallet or two attached to it might last long enough to get on trailer. Pulling it on backwards may be better, may drag better, don't know. May be better to take the other front wheel off and drag whole front suspension/frame on pallets. Pallets are free. Take a bunch with you. Old tires and pallets, what could be more fun smile
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
IBenDcars #1361163 Wed May 20 2020 08:33 PM
I
Thanks for the replies.
The way it is sitting it will go on the trailer backwards.
Definitely not fighting it to turn it around and then fight it up the ramp
IBenDcars #1362541 Fri May 29 2020 03:42 AM
As mentioned, the parts from the donor truck may or may not fit, but it certainly would not hurt to check.
Rich
'47 Loadmaster
Life is like a roll of toilet paper--the closer you get to the end, the faster it goes!
Moderated by  SWEET
