The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (canuck49, 1953 panel, AwDang, 6571, Brad Allen, 2 invisible), 236 guests, and 3 robots.
Forums50
Topics120,082
Posts961,737
Members43,550
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1937 clutch removal
#1360283 Thu May 14 2020 05:43 PM
Q
Quin Offline OP
I have a 1937 216 trying to drop the clutch it won’t drop down out of the bell housing do I have to take it apart further has someone taken one of these before that could give me some information?
1937 clutch removal
Qball
Re: 1937 clutch removal
Quin #1360311 Thu May 14 2020 09:51 PM
If all the pressure plate bolts are removed, the pressure plate and clutch should drop out.
Chevrolet's 1938 Shop Manual
Steps 1, 2, 3
http://chevy.oldcarmanualproject.com/shop/1938/38csm181.html
Quin #1360400 Fri May 15 2020 01:19 PM
Q
Quin Offline OP
Ok thanks I see I have to remove the retracting springs thanks
Qball
Quin #1360408 Fri May 15 2020 01:55 PM
Q
Quin Offline OP
My pressure plate looks nothing like the one in that manual if I remove the spring bolts the whole thing is going spring into pieces and probably drop out but how would I compress it to reassemble while in the bell housing
Qball
Quin #1360419 Fri May 15 2020 03:07 PM
If you check the '37 shop manual you will see that you need to remove the throwout sleeve from the fingers on the clutch cover. There are springs that attach it to the clutch levers.
That should give you the room you need to drop the clutch cover.
Do not take the clutch cover apart while it is still inside the bell housing.
Based on your pictures that is the correct '37 lever style clutch with the carbon throwout bearing. The cars adopted the diaphragm style clutch in 1939. I do not know when the trucks started using that design.
Each of us does our work in a way that fits our style. Unless it is a very unusual situation I typically take the extra time to remove the starter and bell housing when I do a clutch job. It really opens things up for access and visibility.
Rusty
Quin #1360420 Fri May 15 2020 03:11 PM
You don't want to disassemble it. A lot of models you have to push the disc up into the top of the bell housing & drop the pressure plate out first. Its tough on the fingers but that's the way it goes.
George
1956 Chevy 1/2-Ton Pickup
TBUChevy #1360421 Fri May 15 2020 04:03 PM
Q
Quin Offline OP
The bolt for the bell housing are behind the fly wheel so the clutch needs to removed first I do not want to disassemble it while it the bell housing but I see no other way
Qball
Quin #1360424 Fri May 15 2020 04:36 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Read what Wrenchbender said in his post above. Read it again and give it a try. He has been there and done it more than once.🛠
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2)
‘39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
Quin #1360820 Mon May 18 2020 05:15 AM
Q
Quin Offline OP
Wrench bender was correct I got it out thank you
Qball
Moderated by  SWEET
