The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (bcwayne, Kzooandy, MT53, 55 SHAKER, GWWirth, Ga92009), 164 guests, and 4 robots.
Forums50
Topics121,069
Posts970,530
Members43,832
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Valve assembly diagram
#1360260 Thu May 14 2020 02:55 PM
Coltonk Offline OP
Does anyone have a detailed parts diagram showing a typical intake and exhaust valve. I took pictures the best I could while assembled but want to make sure I don't miss anything or get in the wrong order.
Colton Kenshol
Hermiston, Oregon
1950 Chevy 3100
216 Motor
Mostly Original..
Re: Valve assembly diagram
Coltonk #1360267 Thu May 14 2020 03:34 PM
Figure 16 on page 6-12 of the Shop Manual is pretty good: Valve Seal, Cap and Locks Installation Diagram [chevy.oldcarmanualproject.com]. Figure 18 on the same page shows the rocker assembly - 4 distinct parts, 3 of each, left and right intake and exhaust - that have to be assembled in the correct order on the rocker shaft.
Coltonk #1360274 Thu May 14 2020 04:15 PM
Coltonk Offline OP
I've seen that picture but thanks did reminding me of it.. One thing I need more detail is there are so really thin washers below the valve spring (I think) and half of the caps on the valve spring that hold the retainers can spin..
Colton Kenshol
Hermiston, Oregon
1950 Chevy 3100
216 Motor
Mostly Original..
Coltonk #1360288 Thu May 14 2020 06:17 PM
Sounds like what you are describing are shims below the valve spring that may have been used to set the correct closed-valve spring height/tension after the valve seats were recessed some time in the past. The shims may or may not be all the same thickness. Check for correct spring height... that should correct the loose caps if the springs are the correct free length, as they should have a minimum closed tension of 55lb, +/-, higher for newer 235s and 261s. This table may help, from Pre '68 Dave's blog: Valve Spring Pressures and Installed Heights [chev235guy.blogspot.com].
Coltonk #1360295 Thu May 14 2020 06:54 PM
From either end of the head, the valves are:
Ex In In Ex Ex In In Ex Ex In In Ex
Coltonk #1360320 Thu May 14 2020 11:07 PM
I just assembled some this weekend!
It was too tough to use those pictures alone. Many rockers have numbers on them, that's what unlocked the secret for me.
I found out from this thread:
https://www.chevytalk.org/fusionbb/showtopic.php?tid/257275/
Rear RE LI RI LE RE LI RI LE RE LI RI LE Front
Rear 8, 5, 6, 7, 8, 5, 6, 7, 8, 5, 6, 7 Front
Note: my old rockers had an extra 8 in front of all those numbers.
'59 Chevy Suburban, NAPCO
Moderated by  Woogeroo
