The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 members (), 97 guests, and 3 robots.
Forums50
Topics120,492
Posts965,741
Members43,684
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: 235 headers
rad #1360085 Wed May 13 2020 05:54 AM
I have tried both water heat and exhaust heat from the fentons to my standard intake manifold .
The water heat took much longer to achieve effective heat and was ultimately cooler than the exhaust heat . I have ended up using exhaust heat . The truck ran like crap with no intake heat at all .
The truck runs great with the fentons , slight adjustment to the carb (metering rod height) wee tweek on the timing smile smile
Re: 235 headers
rad #1361372 Thu May 21 2020 11:06 PM
Never forget the "chicks dig it" factor and remember that polished parts are more aerodynamic. Both add HP.
Re: 235 headers
rad #1361396 Fri May 22 2020 02:30 AM
I have had a chick or two pretend to dig my shiny parts, but I am nearly certain they had other nefarious intentions.
Re: 235 headers
52Carl #1361438 Fri May 22 2020 12:27 PM
Unrepentant VW Lover
What species were these chicks?
nanner
"There is a life about to start
When tomorrow comes..."
'49 Chevrolet 3804
Re: 235 headers
rad #1361448 Fri May 22 2020 01:19 PM
Rad
I agree with Martin, it's your truck, build it the way you want.
But you can learn alot reading and asking questions on this site.
Off topic: Ignore the two thread stealing hoodlums that just posted, they can't help it.
Also, I see that you have Grafton as your location. I assume that is Grafton Illinois.
If so, check out the Heartland Bolters once in a while. It's about time to liven that area up in preparation for the Stovebolt Reunion.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/forums/68/1/the-heartland.html
There are plenty of bolters around St. Louis.
Don
"The Flag Pole"
In the Stovebolt Gallery [stovebolt.com]
More pix on Photobucket [s893.photobucket.com]
'46 2-Ton grain truck
'48 3/4-ton grain truck
'50 2-ton flatbed
'54 Pontiac Straight Eight
'70 American LaFrance pumper fire truck.
Re: 235 headers
rad #1361474 Fri May 22 2020 03:31 PM
Personally, I understand that most engines don't operate in the RPM range to make efficient use of headers, but you have to admit they sound great. I say use the headers, you get always change back once you find the right manifold.
Craig
Come,Bleed or Blister somethings got to give!!!
Q:"What yah runnin"
A:"3/8 drive Black and Decker aquarium pump motor" (the movie HOTROD)
59' Apache 31, long term project (30 years and counting)
Re: 235 headers
rad #1361491 Fri May 22 2020 05:05 PM
If you had enough room, a tuned length will help, but it's probably close to 50" for the primary to get the RPM down.
The siamese exhaust ports confuse the whole thing, there are 2 "extra" reflections in the 2-3 and 4-5 tubes.
Page 2 of 2 1 2
Moderated by  KCMongo
