The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (Organbuilder, Retired71Blazer, tclederman), 172 guests, and 1 robot.
Forums50
Topics119,951
Posts960,604
Members43,521
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Proper oil for 49 Chevy 4 speed
#1359588 Sun May 10 2020 05:22 PM
TKM Offline OP
Can anyone tell me what is the proper transmission oil for my 1949 Chevy 3600 four-speed? Also, transmission seems to work well but the gearshift is very sloppy. Are there any rebuild kits that can address the sloppiness? Thanks! Tim
Re: Proper oil for 49 Chevy 4 speed
TKM #1359652 Sun May 10 2020 09:12 PM
The '48-'51 Chevy Truck Shop Manual [chevy.oldcarmanualproject.com] lists on page 0-5 the recommended lubricant as 90 wt. I prefer Red Line Oil MT-90, as it is synchronizer friendly, and works well in older transmissions.
Others can probably help better than I on the questions regarding shifter sloppiness.
Doug
TKM #1359657 Sun May 10 2020 09:44 PM
ace skiver
From Novak's website [novak-adapt.com]:
"When filling your 420 with gear oil, we recommend that you select a conventional mineral oil or a para-synthetic in lieu of a full synthetic oil. Properly assembled manual gearboxes do not have the thermal strains seen by combustion engines or hypoid gears. Synthetic fluid in these gearboxes, while not harmful, is probably an economic waste.
Hypoid gear oil is sulphurized higher than transmission oil and can be mildly corrosive to the non-ferrous alloys used for synchros, bushings and thrust washers in these transmissions.
An 80W-90, API-GL5 or MT-1 rated fluid is very good. Some claim faster shifts from using a 50W engine oil in their transmission and we do not consider this to be contraindicated unless you operate your vehicle in a very warm environment."
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
TKM #1359667 Sun May 10 2020 10:23 PM
TKM Offline OP
Hey guys, thanks so much for your help and advice, always like to hear from those with experience !
TKM #1359668 Sun May 10 2020 10:33 PM
Previous posts have recommended - Traveller Ford Tractor All Mineral 90 Transmission Fluid, 2 gal.
SKU: 80660099 at Tractor Supply. $23.
Ronnie
1954 Chevy 3604 - A work in progress...
" You can't keep dancing with the Devil and wonder why you're still in hell"
TKM #1359693 Mon May 11 2020 01:16 AM
Tim, I have to respectfully disagree with the recommendation of using GL-5 fluids for transmissions. The added Sulphur needed to make the GL-5 rating is generally corrosive to synchronizers, and any brass/bronze components, and not needed for other than hypoid rear ends and similar. A good GL-4 fluid is sufficient and synchronizer friendly. Further, fluids that are properly designed for transmission use have the right characteristics that promote smooth shifts. A typical GL-5 gear lube that is great for rear ends doesn't necessarily meet that, either.
Now, I'm not pushing the brand, as there are many choices, but here is a good white paper on the subject, FYI. Red Line MTL and MT-90 Tech Info [redlineoil.com].
Cheers!
Doug
TKM #1359704 Mon May 11 2020 01:55 AM
TKM Offline OP
Doug, I will check out the article, thanks so much for taking time to help, I’m amazed at all the knowledge on this site !!
Moderated by  SWEET
