The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
23 members (69Cuda, Charles in CA, 9% grade, BC59, 5 Window 9434, 3 invisible), 137 guests, and 3 robots.
Forums50
Topics120,447
Posts965,417
Members43,678
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Rebuild of 31 engine in a 34 pickup
#1359142 Thu May 07 2020 09:11 PM
Does anyone know if a 33 head will fit on a 31 block?
Re: Rebuild of 31 engine in a 34 pickup
James McKean #1359362 Sat May 09 2020 03:23 PM
Chevy used the 194ci engine from 1929-33 so it should fit.
Evan
James McKean #1359385 Sat May 09 2020 06:19 PM
1933 came in both Standard and Master, as well as truck. I know the standard has almost nothing that interchanges with anything else.
I am not by a parts book, but a look at head gasket interchange should answer it.
My Blog
James McKean #1359451 Sun May 10 2020 02:42 AM
As long as the head is casting 836961 it should work (this was used in the 1933 Masters and Trucks), the 1933 Standard CC is the only one from 1929-33 that uses a different head gasket...'34 and up are also different.
Since the actual heads changed almost every year form 1929 thru 1936 for various reasons, you will also need the 1933 head bolts (4-5/16") which are longer than the 1931 (4-1/8")...
Mike B smile
coilover #1360203 Thu May 14 2020 02:23 AM
Thanks I'm just get started on the pickup lots of stuff to find out when it comes up.
Pre '68 Dave #1360206 Thu May 14 2020 02:35 AM
Thanks for the help unfortunately I've thrown out the old gasket so what would be the best way to find the right gasket for the head.
Mike B #1360208 Thu May 14 2020 02:51 AM
Thanks for the info, I'm waiting for the head I found to get here before I'll be able to know what the casting number is for sure. I was told it was from a 33 but until it arrives I guess it's a hope and a prayer it's going to be right. Thanks again.
James McKean #1360462 Fri May 15 2020 09:58 PM
OK, new rule ..... Never throw any thing away until the restoration is completely finished .
James McKean #1360470 Fri May 15 2020 10:29 PM
General Purpose
The old rule is never throw anything away.
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
bartamos #1360499 Sat May 16 2020 01:34 AM
Ever!
Been burnt too many times to count, and I don't throw anything away. I do have a wife...
Page 1 of 2 1 2
Moderated by  Woogeroo
