The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (Pete V, Paul_WNC, dirtball, Greg C, rickmg), 99 guests, and 3 robots.
Forums60
Topics124,660
Posts1,006,225
Members44,993
Most Online1,229
Jan 21st, 2020
Image Posting Policy
New Switch Knob for Wipers on 54 truck
#1357416 Mon Apr 27 2020 12:50 PM
Hi Just went through a bunch of parts I had bought from the filling station when I first bought the truck a year ago, and found a replacement knob for the wipers. My current one, is really beat up, like a previous owner had painted it, and removed the paint multiple times, and is rough and kind of nasty. SO, I go to put the new knob on, and it is very loose. Looking at the bottom, you can see that it's not an exact match for the original.
Before I start bending the the arms on the switch itself, any good ideas or tricks for making the new switch fit tight ?
1954 Chevy 3100
Re: New Switch Knob for Wipers on 54 truck
Kevin13Shaw #1357424 Mon Apr 27 2020 01:57 PM
Bubba
Keith, can you attached an image of the top side of both knobs?
Do you remember where you bought your new knob?
I had no problem using the knob from Classic Parts and from Jim Carter (and, Chevs of the 40s looks correct).
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Kevin13Shaw #1357434 Mon Apr 27 2020 03:31 PM
I bought it from the Filling station last year. Here are picts of the top.
1954 Chevy 3100
Kevin13Shaw #1357435 Mon Apr 27 2020 03:31 PM
can you post the picture of the underside on the one you received that works?
1954 Chevy 3100
Kevin13Shaw #1357436 Mon Apr 27 2020 03:53 PM
Bubba
I'll guess that the new one is on the left (too thin a "divider"), resulting in "it is very loose".
Tim
Kevin13Shaw #1357449 Mon Apr 27 2020 05:08 PM
yes, that's what I am finding.
1954 Chevy 3100
Kevin13Shaw #1357456 Mon Apr 27 2020 05:50 PM
I would think if you cut a small piece off of a business card and fold it over, the to thin part of the knob, push it on the switch you probably just solved the problem.
Tommy
59 apache 1/2t
261 short stepside
Kevin13Shaw #1357557 Tue Apr 28 2020 12:00 PM
Simple enough, I'll give that a try.
1954 Chevy 3100
Kevin13Shaw #1358086 Fri May 01 2020 02:30 PM
It mostly worked. I think ill but a but of Playdoh, and try to fill in the hole a little bit
1954 Chevy 3100
Moderated by  ndkid275
