The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (agedhorse, Banjoman, Fox), 234 guests, and 3 robots.
Forums50
Topics120,060
Posts961,569
Members43,548
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Rochester B carb gasket question.
#1357723 Wed Apr 29 2020 11:32 AM
Lugnutz Offline OP
In another post I showed the bottom of my Rochester B carburetor. It has two holes. I concluded that both holes should see manifold vacuum. That might NOT be correct. Here’s why.
I just examined two more carburetors that I have. Both of them have only one hole at the bottom. If you look carefully at the photos, you will see the 4 slot marks made by the gasket. Look at the gasket marks. Notice that the gasket slots do not line up with the hole in the bottom of carb. So, even the one hole carbs have the gasket covering the hole.
I know for a fact that one of the “one hole carbs” ran very well when I used it on my 250ci (presently in storage), yet the gasket blocks the hole. HRL and the ODSS gang at the 2018 ODSS Homecoming checked this one hole carb for vacuum advance while I was there and verified it was working.
Can anyone help me understand?
Re: Rochester B carb gasket question.
Lugnutz #1357792 Wed Apr 29 2020 06:59 PM
If that hole is blocked the carb will run extra rich. It allows vacuum to go to the power valve piston. Without it it will be on full rich all the time. Sure, it may run good but it will waste gas & cause excess carbon & dilute the oil. If the holes don't line up, cut a passage in the gasket to allow the vacuum from the intake manifold to reach the hole in the carb.
George
1956 Chevy 1/2-Ton Pickup
Moderated by  Woogeroo
