The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (blueck, clroehm), 162 guests, and 3 robots.
Forums50
Topics120,898
Posts969,181
Members43,791
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 3 1 2 3
1953 216: Vacuum advance install tips?
#1356575 Wed Apr 22 2020 01:36 PM
Aub1953 Offline OP
I have ordered a new vacuum advance for the distributor on the 216 in my 1953 Chevy 3100.
Any tips on the install? Process looks simple enough, but I figured some of y'all may have practical experience with this job.
Thank you.
Re: 1953 216: Vacuum advance install tips?
Aub1953 #1356619 Wed Apr 22 2020 07:46 PM
Bolt it on, hook it up. No secrets to reveal, at least none I'm aware of.
Aub1953 #1356630 Wed Apr 22 2020 08:41 PM
Can you install the vacuum advance without pulling the distributor?
Aub1953 #1356638 Wed Apr 22 2020 09:10 PM
The distributor must be taken out. Just use some way to ensure that you replace it in the same position you removed it. I mark the rotor in relation to the dist body and the body to a point on the engine.
Ed
Aub1953 #1356648 Wed Apr 22 2020 09:47 PM
I agree with Forty9 about the markings. Also I believe as you pull out the distributor the rotor/distributor shaft will rotate some as the distributor gear comes up and out from the camshaft. Make a mark here also. You need this to go back in exactly as removed so distributor shaft lines up with oil pump shaft. Maybe use your phone to video how things come apart.
Aub1953 #1356651 Wed Apr 22 2020 09:58 PM
x2. I take the distributor cap off and rotate the motor until the rotor is at 12 o’clock to the motor. I mark the distributor body right at the lip where the rotor is pointing with a paint marker. Pull the distributor, with a black magic marker, scribe a line at the top of the clamp all the way around the distributor body shaft. The reason you want to do this is that it is entirely possible to get the distributor installed and the motor running, without the distributor tang engaging the oil pump slot. So the black line helps you confirm the distributor is in at the same depth as it was when you took it out.
install the new advance On the distributor, leave it loose, install the distributor, install the hold down bolt and center the octane selector to 0. body and rotor pointed to 12 o’clock, tighten the clamp screw. You have this!
Mike
Aub1953 #1356662 Wed Apr 22 2020 11:02 PM
Aub1953 Offline OP
You guys are awesome. Thanks for the detailed advice and tips.
Aub1953 #1356672 Thu Apr 23 2020 12:22 AM
If the distributor doesn't drop all the way in, never fear, the oil pump drive gear just has not dropped in yet, do NOT hammer on the distributor, just turn some more until the oil pump drive drops in the slot. If one looks at it, one can figure out on your own.
Ed
Aub1953 #1356727 Thu Apr 23 2020 01:42 PM
I do everything involved with the distributor by starting with aligning the timing marks to no. 1 cylinder. Check the position of the rotor, it should generally point to the 5:00 o'clock position. Disconnect the vacuum line. Pull the cap out of the way. Remove the hold down bolt and loosen the screw holding the advance to the list. shaft. Slide the list out. Remove the old advance unit. life the new one on. re insert the dist. in as close to the same position as possible. If the List. doesn't go all the way down, back it off and turn to rotor one way or the other to see if you can get it to easily slide in and retain the 5 O'clock alignment to the Distributor. body. This may take several tries. If all else fails, jog the engine until the shaft slides in and you have no.1 cylinder and the rotor aligned to No.1 cylinder at the 5 o'clock position. Install the bolt, align the octane lines to the center mark, tighten the screw but not complete yet , and install vacuum line. Static time the engine by hooking a test light to the Distributor side of the coil. turn on the ignition switch, adjust the distributor by turning it until the light just comes on. Lock it down. start the engine and use a timing light to get the final timing perfected. Insure to time the engine in accordance with the recommended RPM.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
My Webshots Album
Aub1953 #1356766 Thu Apr 23 2020 05:45 PM
I didn't remove the distributor to replace the advance on my '38 216. I see no reason why you would???
Page 1 of 3 1 2 3
Moderated by  Woogeroo
