The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (klhansen, 1933GMC, 1 invisible), 143 guests, and 3 robots.
Forums58
Topics122,604
Posts989,107
Members44,491
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Brake Fluid Testing
#1355708 Fri Apr 17 2020 03:08 PM
Apache1 Offline OP
Is there a kit out there available to test MC brake fluid for acidity....etc.?
Re: Brake Fluid Testing
Apache1 #1355715 Fri Apr 17 2020 03:42 PM
Curious minds what to know.....May I ask why?
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
Pictures in my Photobucket [s140.photobucket.com]
https://photos.google.com/share/AF1...Nko1cUJCNFFMTVFEUnNRbjFhNTFPc1J4YWV4cmRB
52 Chevy Panel [photos.app.goo.gl]
Apache1 #1355719 Fri Apr 17 2020 03:56 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Saw one somewhere, don’t remember where though.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
Apache1 #1355738 Fri Apr 17 2020 05:27 PM
Moisture tester:
Amazon:
PTE Tester Calibrated for for DOT 4 Brake fluids
by PTE
4.2 out of 5 stars 467 ratings | 22 answered questions
List Price: $8.49
Price: $6.99 & FREE Returns
You Save: $1.50 (18%)
Get $100 off instantly: Pay $0.00 $6.99 upon approval for the Amazon Prime Store Card. No annual fee.
Color: Calibrated
Quick and easy way to test for moisture content in the brake fluid; results appear in seconds
LED light indicators show percentage of water in the brake fluid
Calibrated for cars using DOT 4 brake fluid only (found in most cars produced since 2006)
Acidity and moisture test strips
https://www.acustrip.com/res/pdf/61000_SS.pdf
https://www.acustrip.com/cgi-bin/proddesc.cgi?s=61000
Takes 1 x AAA/1.5V battery (included)
Only takes seconds to know t
Apache1 #1355740 Fri Apr 17 2020 05:35 PM
I go by the old adage " If in doubt change it out"
38 Chevy 1/2 ton being resto-moded
65 AC Cobra replica
USAF vet
Apache1 #1355742 Fri Apr 17 2020 06:00 PM
Some garages use the moisture checker on a regular basis. Dealerships like to change the fluid every few years.
1951 1 Ton Completed
Apache1 #1355749 Fri Apr 17 2020 07:30 PM
DOT 3 and 4 brake fluid is made with alcohol and glycerine as the basic components. It's "hygroscopic", meaning it will absorb moisture from the humidity in the air. I'd recommend flushing the brake system every couple of years with fresh fluid, rather than try to test it. A couple of cans of new brake fluid and a little time spent bleeding the system is cheap life insurance. DOT 5 fluid is silicone-based and doesn't absorb moisture, but that stuff opens up a Pandora's box of problems when it's used in a system not engineered for it!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Apache1 #1355754 Fri Apr 17 2020 07:58 PM
Apache1 Offline OP
12 year old newer vehicle w/only 1500 miles on the odometer. Garage kept although I suppose it could draw moisture from sitting.
Apache1 #1355760 Fri Apr 17 2020 08:09 PM
DOT 5 should NOT be confused with 5.1 brake fluid
Since DOT 4 and 5.1 are both glycol-based brake fluids they are compatible with each other, which means they can be readily mixed without harming your brake system. It is important never to mistake DOT 5.1 (glycol-based) with DOT 5 which is silicone-based and should never be mixed with any other DOT fluid.
https://epicbleedsolutions.com/blogs/faq/whats-the-difference-between-dot-4-and-dot-5-1-brake-fluid
Apache1 #1355773 Fri Apr 17 2020 08:56 PM
Should I count myself lucky? I've used Dot 5 silicone brake fluid in my 1939 Chevy truck for more years than I can remember. Original Huck brake system. No problems what so ever. I can slam on the brakes and put your nose into the windshield. So what are the problems?
Rick
Page 1 of 2 1 2
Moderated by  SWEET
