Remember
The old Bulletin Board?
click to enter
The old Bulletin Board has been removed from the server. And with recent "spring" cleaning, we are removing links back to it. The BB is still out in cyber space (to some extent) thanks to The Wayback Machine.
Oh Lord, I just gotta find it....
13 members (Donf, 3B, D B Cooper, EchoBravoSierra, 55shaker, Bill Ryle, 2 invisible),
93
robots. |
Key:
Admin,
Mod
Forums59
Topics128,110
Posts1,037,374
Members45,936
Most Online1,229 Jan 21st, 2020
OP
FIRST off Thank you for any reply on my question. I just put a clutch in my truck FRANKEN so i removed the trans and took the shifter out of the trans to take it out of the way . THE pins in the cone that hold the shifter in place seem to me to be way to loose. Can anybody tell me if they are to be pressed in tight or can they wobble .The hold down clamp that is spring loaded does its job when you press it down to lock the shifter in . If i need to get new pins who may have them online THANKS BJF
Once those pins start wobbling they will wear the holes in the shift tower egg-shaped in a hurry. I've fixed that problem by threading the holes and putting a short bolt in from each side, and grinding the end threads off for a snug fit where the shifter pivots. A Grade 8 bolt will last a long time in an application like that, and if it wears, it's replaceable. Jerry
"Freedom's just another word for nothing left to lose" Kris Kristofferson Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
WAG MORE- - - - - -BARK LESS!
SM 420 Shifter Fulcrum Pins GM part # 590282 https://i.postimg.cc/66GRFRRq/SM-420-Fulcrum-Pins.jpgFriesen Chevrolet Sutton, Nebraska phone : 402 - 773 - 5538 Friesen has ( 70 ) fulcrum pins in stock Newton Motors Glasgow , Montana phone : 406 - 228 - 9326 Newton has ( 37 ) fulcrum pins in stock The fulcrum pins are a press fit with no wobble . George '54 3600
1954 3600
OP
THANK YOU AND AS ALWAYS YOU GUY COME THRU, THE BEST INFO BJF
