The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (52Carl, Achipmunk, Harold41, hardshell, 3800GUY, Brad Allen), 109 guests, and 3 robots.
Forums50
Topics119,477
Posts956,640
Members43,409
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 7 of 7 1 2 3 4 5 6 7
Re: 1950 3100 parking brake
Jhyp #1352658 Tue Mar 31 2020 11:40 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
On Wagoner/Lockheed the bottom two bolts are concentric and are part of the adjustment process. Not sure about Huck, I’ve never worked on them.🛠
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2)
‘39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
Jhyp #1352676 Wed Apr 01 2020 01:25 AM
Jhyp Offline OP
Carl, I've had the truck a number of years but never got around to its restoration. That is now nearly done. The individual i purchased it from was using it as a daily driver. Don't know much beyond that. As far as I know everything was original (a few minor exceptions). Don't really know how I would determine if the backing plate or rear axle was ever replaced. As far as the brakes go everything is original with the exception of the brake shoes and wheel cylinder (unfortunately I threw the originals out prematurely). I did purchase a new drum just to see what the actual ID of a new drum was. The replacement shoes and cylinder came from Classic Parts. I called them today to see if they could help or had any ideas. They said they have never encountered this problem and provided no help. I will check the bottom pivot pin and bolts location with Andy as we have been using his 48 or 49 (i forget which) as a reference since his brake geometry seems to be just fine.
Jhyp #1352853 Thu Apr 02 2020 04:44 AM
Good plan. An in-person, side-by-side comparison would solve this problem quickly.
Jhyp #1353188 Fri Apr 03 2020 11:14 PM
Jhyp Offline OP
Andy, here are two more pics. can you look at your brakes and supply me with the requested measurements.
Jhyp #1353242 Sat Apr 04 2020 03:29 AM
Jon,
I should be able to get your measurements tomorrow, late morning.
Andy
His: 1947 Chevrolet 3104 [flic.kr]
Hers: 2008 American Saddlebred [flic.kr]
"A Jack of all trades is a master of none, but oftentimes better than a master of one." - Benjamin Franklin
Jhyp #1353304 Sat Apr 04 2020 04:16 PM
Jon,
Here's what I came up with. Let me know if you need any confirmation.
Andy
Jhyp #1353312 Sat Apr 04 2020 05:24 PM
Jhyp Offline OP
Andy, I compared your measurements with my truck and they are the same (+-)! The geometry is the same. So I am back to square one. The Problem has to be in the shoes, cylinder or drum. Except we have checked all of those. Guess I will have to run the truck with the adjusted screws out to far and no parking brake unless someone with more knowledge than me has a solution. Again, thanks for all your help.
jon
Jhyp #1353316 Sat Apr 04 2020 05:57 PM
Jon,
Based on all of our measuring, comparing, and component swaps. I believe the only variable left is in the internals of the wheel cylinders. The piston, cup, or spring (or all) in the wheel cylinder must not be as thick/long as it (they) should be, causing you to have to crank the adjusters so far out. See Fig.50-Wheel Cylinder Parts Layout [chevy.oldcarmanualproject.com] from the 1948-51 Chevy Truck Shop Manual. Since the geometry all checks out, my recommendation would be find another source for the rear wheel cylinders.
Keep us posted.......
Andy
Jhyp #1353877 Tue Apr 07 2020 03:30 PM
Jhyp Offline OP
I am going to bring an end to this thread that I started. Originally it started as a parking brake issue but I (we) realized that it was really a brake issue. The Problem had to be with The drum, shoes or wheel cylinder. The Problem was when the brakes were fully assembled with new repro parts in order to get the slightest drag on the drums the wheel cylinder adjusters had to be adjusted 1/2" out (way to far). After trying many things the conclusion is that the wheel cylinder body length is to small. I have tried new cylinders from several sources without any luck. So I am going to have to live with the set up i have. Thank you all for your advise, ideas, suggestions and help.
Moderated by  SWEET
