The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (Eisenhart1992, Eureka Jim, HandyAndy, Ed Blouch, bwilliams, 1 invisible), 139 guests, and 3 robots.
Forums50
Topics118,977
Posts952,351
Members43,300
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
1946 COE engine suggestions
#1353440 Sun Apr 05 2020 10:07 AM
29tons Offline OP
Im working on another project. 46 coe I was thinking of installing a Detroit diesel 4 cylinder 471 or 453? But I really would like to put a automatic behind it. or a 5 speed over drive. Anyone have any suggestions. What year what type of trans what did this engine come in? What frame would be best? Thanks for any help
Re: 1946 COE engine suggestions
29tons #1353468 Sun Apr 05 2020 02:35 PM
Boltergeist
Detroit engines are noisy, heavy, smoky, and stinky. They also have a very narrow usable RPM band, so they need a LOT of gears. Even a 4-53 will weigh about twice as much as the original engine. You will need to install a front axle designed to hold the weight of the engine and completely re-engineer the steering system, or put the cab onto a frame designed for the engine. Either approach will cause your checkbook to need CPR. I'd suggest retrofitting the truck with a 292 Chevy 6 cylinder and a Turbo 400 transmission. You'll have more than twice the power of the original 216 engine, and other than fabricating new engine mounts, it should be a pretty simple swap. While you're swapping components, install a GM corporate 14 bolt rear end and you'll have a complete new running gear with affordable, easily obtainable parts, not a Franken-truck with a totally obsolete set of drivetrain components.
Edit: If you're really committed to using a 4 cylinder Diesel, drop the cab onto a chassis for a Nissan 4 cylinder Diesel cabover truck and use the whole frame and running gear. It's engineered to work, and you'll have a modern suspension and steering system and brakes.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
29tons #1353633 Mon Apr 06 2020 01:21 AM
29tons,
What size is your COE? They come all the way from 228 gasser to 6-71 Detroit with appropriate weight running gear.
What is your intended use? Picture?
Ed
EdPruss #1353695 Mon Apr 06 2020 01:21 PM
29tons Offline OP
To use as a pickup but would like some power in case I want to tow something . Also thinking of using a van or Motorhome frame. I was wondering if I should post this on the hipo forum is there an easy way to move this ?
29tons #1353788 Mon Apr 06 2020 10:54 PM
A 261 Chevy or GMC 302 will fit in there quit easily and give plenty of power for intended use.
Ed
29tons #1353800 Mon Apr 06 2020 11:49 PM
I just finished a 48 COE with a duramax and allison transmission plenty of power I also added a hitch in the bed for my 40ft enclosed trailer.
29tons #1353808 Tue Apr 07 2020 12:17 AM
Go buy a silverado with a 4.8/5.3/6.0 and a frame thats broken/rotted in half. Get it for like 3-500 bucks and use the whole drivetrain. Simple, easy, effective. Every parts store has everything to fix it if god forbid it ever needed something while on the road.
29tons #1353858 Tue Apr 07 2020 12:51 PM
I have a Dodge 4wd frame I am going to add a COE body to sometime.
Ed
29tons #1353882 Tue Apr 07 2020 03:56 PM
Boltergeist
One of my neighbors has two items decorating an equipment shed on his farm- - - - -an early 1960's D-4 Cat dozer and an early 1950's Chevy cabover flatbed truck with the cylinder head off and sitting on the bed. I've been trying to buy both of them for years, but he just won't turn 'em loose! (As if I needed another project or two!)
Barnfind49 #1354007 Wed Apr 08 2020 11:15 AM
29tons Offline OP
I would have to measure the side to side measurements to see if it would fit down in the frame .Is a 6.0 ls more narrow than a 350 with exhaust manifolds?
Page 1 of 2 1 2
Moderated by  KCMongo
