EVENTS
Check in for status!
Jump over to the
Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
1 members (Highflyer),
187
robots. |
Key:
Admin,
Mod
Forums50
Topics121,365
Posts977,667
Members44,213
Most Online1,229 Jan 21st, 2020
 Re: Freeze plug
Think I'll start knitting!!
1949 gmc 1-ton
 Re: Freeze plug
General Purpose
Make it the right Diameter.
Watch out for careful drivers!!! I'm away on an ego trip. Will be back on Feb 30. I'm not an Auto Mechanic, but I play one on TV. I charge $0.02 for every opinion and I take Paypal. Plan B is always better than plan A, by definition. You can't teach a new dog old tricks.
 Re: Freeze plug
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
This thread has been officially hijacked! Back on track please.
Martin '62 Chevy C-10 Stepside Shortbed (Restomod in progress) '47 Chevy 3100 5 Window (long term project) ‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) ‘39 Dodge Businessmans Coupe USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one! Support those brave men/women who stand the "Thin Blue Line"! Hug a cop!
 Re: Freeze plug
OP
Hi Johnny. Thanks for the info. Yes it does look like the one on the left. So where can I order one?
1947 3100
 Re: Freeze plug
General Purpose
This [ rockauto.com] is $5.50 for 10 or $5.79 for 1. Unless a cup type would hit something inside the hole or black flow, a cup type would be better/easier to install. you can get a brass 2" diameter cup type which will never rust.
 Re: Freeze plug
Every auto parts store in the world carries freeze plugs. I find it hard to believe you got turned away by NAPA. It’s not even an odd size. You can use either one as long as it is the right circumference but as bartamos said the one on the right is easier for a novice to install.
 Re: Freeze plug
General Purpose
circumference? I'm not taking the bait.
 Re: Freeze plug
 Re: Freeze plug
General Purpose
Make sure of the diameter. The disc [ oreillyauto.com] type are installed with the "dome"/convex facing out. You hammer on it and it expands like a giant welch plug (carbs). The cup type is just pressed/tapped in. if the hole has a ridge/a stop inside, I believe that means you have to use the disc.
 Re: Freeze plug
I believe I used a #2 permatex sealant on mine years ago. Had a machinist recommend I use it on the expansion plugs,it stays soft and doesn't harden up .
