The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (PapaDisco), 229 guests, and 3 robots.
Forums50
Topics120,060
Posts961,569
Members43,548
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
1959 Apache 235
#1352943 Thu Apr 02 2020 07:31 PM
Hi, I installed a Pertronix Ignitor and a flamethrower coil on my 235 do I still need the wire from the foot starter to the coil? Thanks Steve
Re: 1959 Apache 235
Steve1940 #1352958 Thu Apr 02 2020 08:58 PM
If you still have the resistor in the circuit, you will need the wire for a bypass.
George
1956 Chevy 1/2-Ton Pickup
Re: 1959 Apache 235
Steve1940 #1352969 Thu Apr 02 2020 09:58 PM
ace skiver
Try to provide more information in future posts.
1. Presumably you still have a 6v negative ground electrical system in your Chevrolet (?) truck?
Presumably you have a 6v negative ground Pertronix module (what part #)?
If both presumptions are correct, you do not need "the resistor".
What resistor, and, where is the resistor?
2. Possibly you have a 12v conversion negative ground electrical system?
Presumably you have a 12v negative ground Pertronix module (what part #)?
If both presumptions are correct, I think you do not need a resistor in the starting circuit.
I think that Pertronix has diagrams somewhere on their website?
I'll look for them after you clarify what you have - or, you could look for them on Pertronix's website.
If I am incorrect/incomplete, someone will correct/clarify.
This Installation Manual might help [pertronix.com]- but, I cannot read it.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: 1959 Apache 235
Wrenchbender Ret. #1352970 Thu Apr 02 2020 10:09 PM
ace skiver
George
For George & Steve: what resistor, and, where?
I have seen/read-about "ballast wires" between the ignition switch to the coil;
and, I have seen ballasts resistors in the lead from ignition to the coil;
and, I have seen "ballasted" coils (VW, I think)?
Tim
Re: 1959 Apache 235
tclederman #1353065 Fri Apr 03 2020 11:50 AM
Hi, motor is a 1959 235 12 volt neg ground with the voltage regulator still there on the fire wall. I will look for the part number on the Pertronix today I could not find any info about the wire from the foot starter to the coil on the pertronix site but will do some more digging . Thank you all for the response. I don't have the wire from foot starter to coil hooked up a little slow cranking at first before motor starts.
Re: 1959 Apache 235
Steve1940 #1353099 Fri Apr 03 2020 02:30 PM
The resistor on that model is a ceramic unit on the outside of the firewall near the v.reg. & horn relay. Read the directions on the Petronix carefully. Some combinations use a resistor in the circuit & some don't. It is important to get the right setup. The last one I had was a 56 I put Petronix on. I used the resistor. It worked fine, started instantly but I accidently left the key on without the engine running one time when I was testing lights. Over night it blew the coil wide open.
George
Re: 1959 Apache 235
Steve1940 #1353196 Sat Apr 04 2020 12:02 AM
Hi, No resistor on the firewall at all looks like there never was one mounted. Tim it is a 1168LS and a 3.0 flame thrower coil. I will do some more research on this. I am not to good with the electrical stuff but I am learning. I will call the tech department on Monday. Again thanks for the help.
Re: 1959 Apache 235
Steve1940 #1353209 Sat Apr 04 2020 12:37 AM
ace skiver
That is a 12v negative ground unit.
No ballast resistor is needed.
Installation Instructions [manualshelf.com]
(scroll down for full size pages)
Tim
Re: 1959 Apache 235
Steve1940 #1353228 Sat Apr 04 2020 01:56 AM
General Purpose
With Pertronix, when you use their Flamethrower coil, you do not need a ballast resistor or the wire from side terminal. Positive coil terminal gets Pertronix red and ignition "ON". Two wires.
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
Re: 1959 Apache 235
Steve1940 #1353232 Sat Apr 04 2020 02:17 AM
Ditto. No resistor needed. But do make sure you are using the right coil. Some pentronix ignitions used 3.0 coils, some used 1.5 coils. Besides that easy peasy. And if you leave the key on. Yep coil will fry.
Page 1 of 2 1 2
Moderated by  Rusty Rod
