The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Remember old days
Remember
The old Bulletin Board?
click to enter
The old Bulletin Board has been removed from the server. And with recent "spring" cleaning, we are removing links back to it. The BB is still out in cyber space (to some extent) thanks to
The Wayback Machine.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (Daves46pu, Bill Hanlon, carbking, 58caddy, 6571, Justhorsenround), 106 guests, and 3 robots.
Forums59
Topics128,095
Posts1,037,207
Members45,931
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
I have a rust free 1950 Suburban shell that is sitting on a frame. Previous owner put new front floor panel in without seat riser. Missing all seats. Trying to decide whether to locate and install original factory seat set or, modern seats that would tilt forward for access.
Thoughts appreciated to help me decide what direction to take .
Tom
Tom I have a factory seat riser if your interested in going that route
Person-to-person offers should be made in a Private Message - Thanks
In reality you're choosing more than just which seats to use, you're deciding the entire future direction of this truck build - restored or modified.
There are occasionally some original Suburban seat sets on Ebay, but they cost a fortune. Check out MNSmith's build thread - he fabricated his own set of very original looking Suburban seats.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1286813/24.html
Since my truck was an economy build I went the other route and used a cheap set of GM buckets.
1951 Chevy Panel Truck
My son has a 49 3800 panel. He used 94 Silverado buckets. They have the tilt and slide action that was used up until the 3rd door was added to extended cab trucks. You can climb over/between them easily enough, they sit on the stock floor just right with the 94 risers, and you can easily find covers for them. Not super common as most were 60/40 split bench but you could go that route as well. I think the 3rd door was a 1996 option.
Just here for the free beer.
1953 1-Ton Dump Truck
1954 Teenage Hot Rod
I used Silverado seats, 2003 I think, in my 52 panel and loved them. Driver seat is power, reclines and seat belts are part of the seat. Also has fold down arm rest. A nice set can be had for good prices at pull a part places. Mine were nice fabric for $250 but you may fine cheaper if you go this route.
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
52 Chevy Panel [photos.app.goo.gl]
Pictures in my Photobucket [s140.photobucket.com]
https://photos.websearch.com/share/...Nko1cUJCNFFMTVFEUnNRbjFhNTFPc1J4YWV4cmRB
I used I think 2004 Chevy Tahoe. I picked up leathers buckets and back seat for around $325. Like others I liked that the sealbelts were built into the seat#. If you go this route you should add strengthening plates under the floor boards as seat are only thing holding you in case of accident.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
Fox Offline
I also used a bench from a 1988-94 Chev truck. It’s a little wide but installed easily enough. I’m 6’ and used a 1” riser on mine. I find that height perfect for elbow out the window cruising height. It fills the cab from door to door, with about 1/4” between door and seat, but I can live with that. It folds down, lots of under seat storage, my wife can reach the pedals (5’7”), and it was cheap. $100for the seat, $60 to have it cleaned. I love those seats.
https://photos.app.goo.gl/1YFEho6LeGdE9EQPA
In the Stovebolt Gallery [stovebolt.com]
More pictures here [photos.app.goo.gl]
1951 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- Rusty- the puzzle box lid for the C10.
1950 Chevrolet 1300- in progress to shiny.
1962 AMC Rambler American- my wife’s
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
Well I guess I made up my mind and found two stock front seats - after all. For my taste, it felt better to stay true to original. I need to better understand if reinforcement steel was used under the passenger seat. I replaced the entire front floor on this suburban with the larger floor assembly rather than piecemeal in the left and right patch panels.
Found the seat riser too.
Next steps - can someone take measurements for the location of the riser? And same for passenger seat? And send me a picture of your measurement sketch? PM me for my contact information.
Wish there was a catalog seat cover kit available for these.
I think there was a square piece of heavy gauge sheet metal tack-welded to the floor under the "jump seat" (maybe TrknGMC, or others, will post some info?)? I think that photos have been poster here, over the years.
Jim Carter sells a 47-55st Suburban upholstery set. Maybe you can find it in his on-line catalog. Or, call him.
There were two slightly different-width seat cushions used on 47-55st Suburbans (I do not know when the change took place). Jim Carter's upholsterer should have the patterns for both sizes. My guess is that 1950 would have the slightly smaller seat cushions (the size that JC normally sells)?
Also, Jim Carter's Suburban Suburban upholstery installation kit does not contain one of the original layers of "stuffing" material - a coir matting layer (some members have used a piece of heavy/firm-nap carpet under the top soft/fluffy-material layer).
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Thanks, Tim. I’ll see what JC offers and measure the seats I acquired. Not sure if they are the wide or narrow seat. But to be honest, a wider seat is better suited for me according to Karen. Not sure what she Is implying ...
Page 1 of 2 1 2
