The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (Old chevy, klhansen, MarkT, Nuts&Bolts, KEVINSKI, 1 invisible), 230 guests, and 0 robots.
Forums50
Topics122,214
Posts980,446
Members44,177
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Help on bed assembly on 51 3600
#1351768 Thu Mar 26 2020 06:37 PM
I'm getting a 1951 3600 put back together - when I purchased it the bed was in pieces. I'm trying to put the pieces back together.
I have the front cross sill, three centers cross sills and the rear cross sill. I see there should be a pad and a block under each sill (on each side), however is the block the same height on all the sills? It looks like the rear sill should have the shortest (if any block). What are the block heights?
Also one of my center sills has brackets welded on the ends - is that from the factory? Does that sill go in a particular location?
Any advice on getting the bed assembled and installed is much appreciated.
front and center sill
Re: Help on bed assembly on 51 3600
gterhorst #1351773 Thu Mar 26 2020 07:09 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Go to Mar-K.com. They have detailed measurements and instructions on the website.
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
gterhorst #1351794 Thu Mar 26 2020 09:13 PM
Shop Clutterist
Check out this thread. There are links to pictures that you may find helpful....
https://www.stovebolt.com/ubbthread...sembly-and-installation.html#Post1310333
Gord
1954 1/2 ton 235 4 speed
gterhorst #1351919 Fri Mar 27 2020 01:41 PM
Yes, there should be a wood block under each cross sill that has a bed to frame bolt except the rear sill, which sits directly on the end of the frame.
That cross sill with the brackets is the second from front. You will see the extra holes in your bedside and angle strip where that bracket attaches.
Good luck with the project
Mar-Ktech
Last edited by Mar-Ktech; Fri Mar 27 2020 04:06 PM. Reason: errors in original post
