The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 members (Joe W, klhansen, kperry, 1 invisible), 136 guests, and 3 robots.
Forums58
Topics122,603
Posts989,107
Members44,491
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Lazy man's Bed Wood
#1351044 Sat Mar 21 2020 08:52 PM
cmayna Offline OP
Back in 2001 I had to do something with the rotted out bed wood. I was too lazy to go thru the exercise of installing correct planks with the metal bed runners between each piece of wood. Thought "Hey! what about a piece of plywood?" Oops, most commonly found plywood is/was 48" wide. The bed is 50". Argh!!
Then I heard about a local lumber yard that sold Ping Pong table wood which is 60" wide x 108" long x 3/4" thick. Yeah Baby!! Grabbed a chunk, brought it home and cut it to size. Pretty easy to install.
Still wanted the metal runners so I simply drilled the hole through the plywood and whoola!
Yes, the wood needs a sealer really bad and maybe this coming summer, I'll do that. Not bad for something I did 19 years ago, especially with all the gravel and rock the green turd has hauled for us.
The dark rubber sheeting up against the cab is my bed protector which lays out flat covering the entire bed when I am hauling rock, top soil, gravel, etc.
Just wanted to share....
Craig's '50 Chevy 3100 5 window
My truck
If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
Re: Lazy man's Bed Wood
cmayna #1351056 Sat Mar 21 2020 09:39 PM
Workshop Owner
They'd probably not let you in Pebble Beach, but looks good to me. thumbs_up Nothing like a little "Stovebolter Ingenuity".
J Lucas
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
1959 Chevy Apache 31 Fleetside
1959 Chevy Apache 32 Fleetside
1959 Chevy Viking 40
My Flicker Photos! [flickr.com]
cmayna #1351565 Wed Mar 25 2020 01:29 PM
Plywood that hasn't separated in 19 yrs is remarkable. Not even marine grade stuff. Clever chug
cmayna #1351581 Wed Mar 25 2020 02:38 PM
Simply wonderfully done. And it obviously great idea for a rather long term fix. Awesome
cmayna #1367207 Tue Jun 30 2020 08:29 PM
I wish I'd known about ping-pong table wood. I used standard 48" wide siding but added metal runners at the edges to hold it down and fill the gaps. The plate is for battery access.
1951 Chevy Panel Truck
cmayna #1367243 Wed Jul 01 2020 01:23 AM
There’s many variations of 5’ x 9’ plywood available.
Just not found at the Box stores.
Marine / boat supply or lumber specialty distributors carry it or have it readily available.
I once bought a 5’x10’ x 3/4 “ sheet with sandy/pebble marine finish thru a boat restoration place.
cmayna #1367268 Wed Jul 01 2020 03:28 AM
Paint that baby dark green with the ping pong table white lines on it. Put a net in the middle too. That would turn some heads!
cmayna #1368175 Wed Jul 08 2020 01:26 AM
Used exterior plywood in my '63 SWB but with cutting it into strips on the table saw, 48" was just enough. I also plowed a groove with the table saw in the edges for the metal strips to sit in. Installed and linseed oiled the daylights out of it. looked great all the time I had the truck.
Larry
All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
