The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (50Chevy3100, draglink, GMCJammer51, FinnBolt, cmayna, 2 invisible), 188 guests, and 2 robots.
Forums50
Topics122,167
Posts979,971
Members44,165
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Clutch head screws
#1350598 Wed Mar 18 2020 10:26 PM
LeeD Offline OP
I was removing the transmission floor cover and had some trouble with the clutch screws. The driver set I have has sizes 3/16 and 1/4, but one is too big and the other too small. I got the 3/16 to work, but I feel that if the screws had been really tight I could have easily stripped them. Once I got them out I tried cleaning them (thinking that maybe they were just full of paint and stuff so the 1/4 would not drop in), but that did not help. My question is am I doing something wrong? Or is there a 7/32 size out there somewhere?
I could grind the 1/4 inch down a little bit if necessary.
Thank you,
Lee.
1956 Chevy 3200, 235 w/3 speed
Re: Clutch head screws
LeeD #1350705 Thu Mar 19 2020 06:07 PM
Lee,
My two cents worth: the new clutch head drivers are a hair off the original size, maybe just mass produced?. I did shave a hair off two of my ( socket set) drivers to make a tight fit.
I also bought a NAPA set (screwdriver style) they seem to fit better than the socket set.
Todd
LeeD #1350707 Thu Mar 19 2020 07:07 PM
Would a piece of emery cloth tighten the grip enough?
Ed
LeeD #1350712 Thu Mar 19 2020 08:15 PM
Lee,
I don't think there is 7/32 size in clutch head, at least I have not seen a fastener that size on my trucks. My drivers are from NAPA, somewhat pricey, but fit very well the fasteners on all my Chevys.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
LeeD #1350758 Fri Mar 20 2020 02:51 AM
Here is what sizes I have in my collection. 5/16. 1/4, 3/16, 5/32, 1/8, 3/32.
LeeD #1350794 Fri Mar 20 2020 12:26 PM
LeeD Offline OP
Thanks for all the replies, sounds like my best bet would be to go to NAPA and find a good set. In the meantime I’ll grind a little bit off the other set to make them fit.
Lee.
LeeD #1350848 Fri Mar 20 2020 06:23 PM
I have a set of clutch head bits, but have also ended up using a regular flat screwdriver to remove some clutch head bolts when the bits didn't have a snug fit and was worried about rounding them out.
A 28 year old with a soft spot for old stuff!
My Pictures [get.google.com]
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 (Dad's truck)
1958 Chevy 3800 w/ 9 foot bed (Current project)
1959 Chevy Spartan 100 (10400)
LeeD #1350858 Fri Mar 20 2020 07:41 PM
I tried to save as many of the clutch head screws I found on my 50
Don’t think I ran into the oddball size
LeeD #1350936 Sat Mar 21 2020 07:39 AM
I bought a set of cheap clutch head drivers from a chain store and they didn't fit Chevy screws. So I got the set from Classic Parts and they worked perfectly.
1949 Chevy Panel Truck
LeeD #1350953 Sat Mar 21 2020 12:39 PM
LeeD Offline OP
I am in Dallas for work (enjoying all the closed restaurants!) and won’t be home for a couple of weeks. I’ll try grinding down the 1/4 inch and see how that works. Maybe I can find an open NAPA store around here and buy a set. It would be nice to have a set that will fit in my magnetic screwdriver; my current set only works with a 3/8 ratchet.
Thanks again,
Lee
Page 1 of 2 1 2
Moderated by  Justhorsenround
