EVENTS
Check in for status!
Jump over to the
Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Forums50
Topics121,369
Posts977,722
Members44,215
Most Online1,229 Jan 21st, 2020
 Re: New gas tank from LMC
I ll second that. Put a spectra premium in a 49 gmc. Perfect fit. No headaches. John
1949 gmc 1-ton
Boltergeist
i would comment but i would be banished for vendor bashing...............its happened before!
I am sure that the reason for the larger outlet is for the people who install V8s in there trucks, that need more fuel flow. I suspect they just figure people will use an adapter to fit whatever size one needs.
See the USA in your vintage Chevrolet! My Blog
I am sure that the reason for the larger outlet is for the people who install V8s in there trucks, that need more fuel flow. I suspect they just figure people will use an adapter to fit whatever size one needs. If they expected people to do that, at least they'd use pipe threads in the outlet instead of some weird threads that you have to hunt to find an adapter. With pipe threads, it would be a snap to adapt the original 1/8 NPT threaded outlet. You can find a bushing just about anywhere.
Kevin First car '29 Ford Special Coupe #2 - '29 Ford pickup restored from the ground up. Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] Busting rust since the mid-60's
The bottom outlet was not the only issue on some of the overseas tanks If bottom threads are metric it might be difficult finding an Adapter to 1/8 npt The filler neck at times would not align ....Denny’s example...
Wish this post was out there a year ago.. Got a tank from a local shop for a '49 3100 with the misaligned filler neck and the profile would not fit the mounting brackets on the floor without modifying them brackets.
Rusty
