The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (GradyB, papas52, mo2cyl, KB65chevy, 49 3100, 1 invisible), 168 guests, and 3 robots.
Forums60
Topics123,368
Posts995,545
Members44,646
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Green Gas ?
#1350576 Wed Mar 18 2020 09:14 PM
I know it just was st paddys day but... my old truck has a miss and thought it may be water in the gas so i drained some into a glass jar to look at and it was green !! Smells old no water sep,I had put stabil additive in it recently.It has rec 90 gas which is suppost to be low alcohol . Any thoughts?
As for the miss plugs look good , not backfiring just seems low on power and has a stutter from 900 to 2500 rpm. idles ok.
Re: Green Gas ?
59chevy36 #1350583 Wed Mar 18 2020 09:25 PM
Are you sure it's not diesel? That has a slight green tinge to it.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Re: Green Gas ?
59chevy36 #1350590 Wed Mar 18 2020 09:37 PM
don't think its diesel. Had some rec90 in a can that's new it looks clear, put a few drops of stabil in still clear. ? could old gas be growing a mold?
Re: Green Gas ?
59chevy36 #1350592 Wed Mar 18 2020 09:46 PM
Green gas?
St. Patrick's Day was yesterday. chug
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: Green Gas ?
59chevy36 #1350595 Wed Mar 18 2020 10:13 PM
Have you had any work done to the fuel tank? A liner kit
Re: Green Gas ?
59chevy36 #1350600 Wed Mar 18 2020 11:08 PM
Sounds like old gas to me. Always turns green. If fuel level is low enough, you might be able to add enough new gas to burn through it. Otherwise, siphon/drain it.
1957 Chevy 3200
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated
Re: Green Gas ?
59chevy36 #1350618 Thu Mar 19 2020 12:07 AM
Not being irish didn't know it had passed , could be old gas. gona drain the tank this week and see what that does. looked/smelled some reg gas e85 and the diesel for the tractor both are clear and smell like they should. when I say green I am talkin lime jello green not just a tint.
Re: Green Gas ?
59chevy36 #1350623 Thu Mar 19 2020 12:28 AM
Ive had old gas turn a honey color
Might be a good idea to clean lines, maintenance on carb
Re: Green Gas ?
59chevy36 #1350639 Thu Mar 19 2020 02:44 AM
How old is the Green Gas?
Do you have copper fuel lines?
Mike B smile
Re: Green Gas ?
59chevy36 #1350641 Thu Mar 19 2020 03:02 AM
Insomniac
If you lived here and the gas was purple, I would say you used the pump that's for boats and farms. Purple gas is not for highway use - no road tax paid.
Gord
1954 1/2 ton 235 4 speed
Page 1 of 2 1 2
Moderated by  Woogeroo
