The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (crenwelge, Turbo4whl, 1 invisible), 234 guests, and 3 robots.
Forums60
Topics123,373
Posts995,633
Members44,648
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 5 of 7 1 2 3 4 5 6 7
Re: 1950 3100 parking brake
Jhyp #1349811 Fri Mar 13 2020 06:11 PM
Jhyp Offline OP
Just to bring closure to this thread. I purchased a new set of rear brake shoes to see if that made any difference. Shoes were the only thing I didn't triple check. Any suggestions i got from Stovebolt I tried but nothing worked. Unfortunately the new shoes did not fix the PB problem! The PB lever still hits the axle before engaging and the wheel cylinders are still screwed out way to far to get the slightest hint of a drag. I'm stumped! Thank you to all who helped. Looks like I'll be driving without a parking brake.
Jhyp #1349819 Fri Mar 13 2020 08:10 PM
Just a thought. Do you possibly have Bendix PB levers on Huck brakes?
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Jhyp #1349821 Fri Mar 13 2020 08:47 PM
Jhyp Offline OP
The correct Huck levers are installed. Tkx.
Jhyp #1349822 Fri Mar 13 2020 08:55 PM
In my opinion, you do not have a parking brake issue.
Given that your wheel cylinders are nearly cranked all of the way out in order for the shoes to make contact with the drums, leads me to believe that your issue is elsewhere. None of the parking brake parts can have any affect, nor can they overcome the cranked out cylinder screws.
Don't know if that helps. Its just my 2 cents.
Jhyp #1349829 Fri Mar 13 2020 10:00 PM
Jhyp Offline OP
Thanks Carl. Don't know where else to look. Tried new shoes. No effect. Tried new cylinders. No effect. Measured inside of rear drum. Same inside diameter as a new drum (11"). Handy Andy and I have tried everything we can think of.
Jhyp #1349833 Fri Mar 13 2020 11:14 PM
Do you happen to have a pic of this.? Im not following the axel portion.
Jhyp #1349858 Sat Mar 14 2020 01:55 AM
Jhyp Offline OP
Dads50, look back in this thread to Feb 8. The pics are there.
Jhyp #1349867 Sat Mar 14 2020 12:10 PM
Ok.
Im thrown off because my 50 has the other style brake
Sorry cannot help
Jhyp #1349924 Sat Mar 14 2020 06:02 PM
You need to find someone who has the same year truck who is in the process of doing a brake job so that you can compare parts.
You either have wrong parts or a part installed in the wrong position.
Jhyp #1349928 Sat Mar 14 2020 06:22 PM
If you look at the post on 2/14 it appears the spreader is shorter than the one handyandy posted?
But the photo could be deceiving
Moderated by  SWEET
