The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (59 fleet, 48bigtrucks, 52Carl, Achipmunk, 3800GUY, 4 invisible), 91 guests, and 3 robots.
Forums50
Topics119,477
Posts956,640
Members43,409
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Front Disc Brake conversion problem
raleigh58 #1349814 Fri Mar 13 2020 06:58 PM
DADS50
You and I are on the same page. My brake pedal will not fully return and therefore causes the brake light switch to stay activated. This happened early on and ran my battery down. Now I at least know to check before parking the truck for an extended period. Doing my paying job today. Perhaps the wife can help me a little with diagnostics tomorrow.
Thanks for your assistance.
raleigh58 #1349831 Fri Mar 13 2020 10:54 PM
I had to add brake pedal return springs so the brake lights would go off.
Wayne
1938 1-Ton Farm Truck
Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. malmwayne@hotmail.com
raleigh58 #1349918 Sat Mar 14 2020 05:46 PM
I have a spring but still lift up on the bottom of the brake peddle when shifting to ensure the light stays off
raleigh58 #1350193 Mon Mar 16 2020 02:09 PM
I have a BIG brake pedal return spring and getting really tired of having to reach down and lift up on the brake pedal to not only make sure the brake lights are off, but to release the brakes from them staying partially engaged. Not a very fun drive nor is it safe.
John in NC
raleigh58 #1350227 Mon Mar 16 2020 06:16 PM
How does the alignment look between the mc and the brake pedal attachment?
Do you have a pic you can post?
raleigh58 #1350239 Mon Mar 16 2020 07:29 PM
Boltergeist
If you can make the brakes function normally by pulling up on the pedal with your toe, common sense dictates that you need a stronger pedal return spring. There should be NO contact between the pedal linkage and the master cylinder or the booster plunger before the pedal travels at least a healthy fraction of an inch- - - - -just like a clutch pedal.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
raleigh58 #1350303 Tue Mar 17 2020 01:07 AM
I had the same problem with my power brake system under the floor, and had to replace the new booster as it was defective out of the box. Adding a bigger spring did not consistently solve the problem. If yours is power brakes they probably need to replace the vacuum booster. The new booster solved the problem completely for me.
Mark
raleigh58 #1350325 Tue Mar 17 2020 03:21 AM
Also make sure the pedal isn't dragging on the floor board, floor mat or carpet. I had the carpet pad get pinched in the floor board pedal hole cause that same problem...
Mike B smile
Mike B #1350359 Tue Mar 17 2020 01:25 PM
I believe my problem is with the booster. Plenty of room around the pedal to not get stuck on the firewall, no carpet to get caught on and only the thin rubber floor mat. It seems to have progressively gotten worse since we picked up the truck in October.
raleigh58 #1352257 Sun Mar 29 2020 06:10 PM
My restoration included having disc brakes with a power brake booster installed for the front brakes only. I stayed with drum brakes on the rear. Just wondering if anyone has installed a #5559BB from Classic Performance Products, Inc. and how it worked or didn't work for you.
Page 2 of 2 1 2
Moderated by  SWEET
