The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
21 members (clarsen3100, 52Carl, GasHog, EdPruss, 2 invisible), 102 guests, and 3 robots.
Forums50
Topics119,516
Posts956,961
Members43,424
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
parking brake
#1349226 Sun Mar 08 2020 03:49 AM
woof359 Offline OP
any one have a good clear picture of the parking brake pedal set up for a 1952 3100 ? I have a pedal that works but no locking parts, no hole in the floor where I have seen pictures of a curved rod going down to some thing ? found the release rod in the back but not sure what it hook to. Thanks
woof359 Family 1952 3100 5 Window
Re: parking brake
woof359 #1349228 Sun Mar 08 2020 04:15 AM
....50 1/2 ton...
Not sure if above link will work or if same as your year
Re: parking brake
woof359 #1349229 Sun Mar 08 2020 04:16 AM
Here is what all the parts look like, the short upright on the Z-bar is where the rod attaches back to the center bar that pulls the cables.
https://www.flickr.com/photos/advance-design_parts_co/8129470811/in/album-72157631868452754/
https://www.flickr.com/photos/advance-design_parts_co/49632576498/in/album-72157631868452754/
Re: parking brake
woof359 #1349238 Sun Mar 08 2020 12:25 PM
ace skiver
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: parking brake
woof359 #1349254 Sun Mar 08 2020 02:20 PM
woof359--make sure the 4.603 rod is clean/no paint--sand it smooth..Had trouble years back when installed in my 49--Bill
Re: parking brake
woof359 #1349256 Sun Mar 08 2020 02:39 PM
No hole in floor panel?
Re: parking brake
woof359 #1349260 Sun Mar 08 2020 03:43 PM
ace skiver
Originally Posted by DADS50
[quote=woof359]no hole in the floor where I have seen pictures of a curved rod going down to some thing ? found the release rod in the back but not sure what it hook to. Thanks
Quote
Was that floor panel replaced/repaired (by you, or, by previous owner)?
Tim
Re: parking brake
woof359 #1349274 Sun Mar 08 2020 08:03 PM
Re: parking brake
DADS50 #1350582 Wed Mar 18 2020 09:25 PM
woof359 Offline OP
those pictures helped alot, many thanks
Re: parking brake
tclederman #1350585 Wed Mar 18 2020 09:26 PM
woof359 Offline OP
previous owner took it some where, nice job but the didnt redo the e brake hole or mounting pointes
Re: parking brake
woof359 #1350603 Wed Mar 18 2020 11:15 PM
They didn't do you any favors
Is the parking brake bracket assembled? That will locate the hole for you
Re: parking brake
DADS50 #1350739 Fri Mar 20 2020 12:14 AM
Attached is photo of the bare-metal flange (correct term?) where the pedal and shaft assembly go thru the floor panel in my '48 Chevy 1/2 ton truck. Did it come off the assembly line looking like this, or should it be painted black? Also, what did the original fasteners look like? I do realize that very few people will ever see it with it being covered by the floor mat. Thanks. LUKE
Re: parking brake
fonz8261 #1350767 Fri Mar 20 2020 03:34 AM
Looks correct to me. Probably cadmium plated originally. Rustoleum Silver Metallic spray paint makes for a wonderful replication of cadmium plating if sprayed over Rustoleum Self-etching primer. It flows horribly and somewhat splotchy, which matches Cadmium plating perfectly.
Re: parking brake
52Carl #1352654 Tue Mar 31 2020 11:19 PM
Here is the "after photo"--the cleanup is complete...
Page 1 of 2 1 2
Moderated by  SWEET
