The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (BC59, Hotrod Lincoln, Lightholder's Dad, dougs, Greg_H, 1 invisible), 187 guests, and 4 robots.
Forums50
Topics121,045
Posts970,422
Members43,829
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
1948 3600 brakes failed.
#1349165 Sat Mar 07 2020 08:29 PM
when first got my restored 1948 3600 chevy, the master cyclinder reservoir was dry. i filled it up and bled the brakes brakes workd fine for about 3 months. i took it out today and went to stop and nothing, right to the floor, looked and master cylinder needed fluid ( a lot). it filled, hand pump a few times to see if i could get air bubbles in MC but nothing. put the cap back on the MC, proceeded to. bleed the brakes and still nothing. looks like a fairly new MC, does this sound like MC failure????
1948 3/4 ton Chevy Pickup
Re: 1948 3600 brakes failed.
MontanaLee #1349166 Sat Mar 07 2020 08:41 PM
Did you find a puddle of brake fluid anywhere? It had to go somewhere.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
klhansen #1349167 Sat Mar 07 2020 09:12 PM
that remains a mystery no evidence that i can see.
MontanaLee #1349174 Sat Mar 07 2020 09:40 PM
Brake fluid doesn't evaporate, so it's either on the floor, puddled up on the frame somewhere or inside a drum...
Mike B smile
MontanaLee #1349178 Sat Mar 07 2020 11:10 PM
Does the vehicle have a Hydrovac unit or other vacuum assist ?
Mike B #1349183 Sat Mar 07 2020 11:49 PM
no just drump brakes-----
also does not explain why i don't seem to be able to bleed the brakes now. i will check the wheel cylinders , it is my only guess now- leaky wheel cylinder.
MontanaLee #1349217 Sun Mar 08 2020 02:36 AM
Am I understanding you correctly...with a full MC you can't get any fluid to come out of the bleeders. Even if the wheel cylinders are leaking, you should still get fluid out of them when you open the bleeder valve.
Are your brake lines all new or recently replaced (steel and rubber)?
As you said, it's time to pull all four drums and inspect for leaks...
Mike B smile
MontanaLee #1349240 Sun Mar 08 2020 12:40 PM
no i was able to get fluid out of bleeders, with no air. next stop pulling the drums
MontanaLee #1349298 Mon Mar 09 2020 01:13 AM
If the brakes failed and peddle floored, but no fluid loss on the ground. I would look at all 4 corners. What m/c setup do you have? Firewall mounted, under floor mounted? Like previosly stated, fluid went somewhere. If firewall mounted and you have carpet, look under carpet.
glenns towing #1349474 Tue Mar 10 2020 05:12 PM
it is an under the floor MC, with no visable puddle
Page 1 of 2 1 2
Moderated by  SWEET
