The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (Cosmo, Bread, Bill Marlow, 63stepsideLB, 68ironhead, 2 invisible), 206 guests, and 3 robots.
Forums50
Topics120,619
Posts966,889
Members43,723
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Cylinder head I.D.
#1349115 Sat Mar 07 2020 08:33 AM
Dusty Offline OP
Is the cylinder head for a 1954 (truck) 235 (high water pump engine) , the same as the 1955 235 PG head (low water pump engine) ??
Re: Cylinder head I.D.
Dusty #1349120 Sat Mar 07 2020 12:31 PM
ace skiver
Those cylinder heads should interchange.
They both use 18 head bolts - same sizes in same locations.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Dusty #1349140 Sat Mar 07 2020 02:43 PM
1953-62 235 heads will all interchange.
The 1953 head is not drilled for the four bolt valve cover, and the 1956 and later have a larger hole for the temp sender, also slightly higher compression.
My Blog
Dusty #1349148 Sat Mar 07 2020 04:06 PM
ace skiver
Thanks, as usual, for the details/corrections, Dave
Tim
Dusty #1349163 Sat Mar 07 2020 07:34 PM
Dusty Offline OP
Thanks guys , that's excellent info , just exactly what I needed .
Moderated by  Woogeroo
