The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (49nut, Aub1953, Gmc101, Hookalatch, 2 invisible), 109 guests, and 3 robots.
Forums50
Topics119,511
Posts956,946
Members43,419
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Removing rear engine crossmember
#1349111 Sat Mar 07 2020 04:58 AM
Is there any danger of the frame "shifting" on my '50 3100 if I temporarily remove the back engine crossmember? It won't allow the space for installing an LT1 with a 4L60E tranny without modifications. Once I have the combo where I want it, I will reinstall it with the necessary modifications completed. I won't remove any other factory crossmembers.
Re: Removing rear engine crossmember
Rocket man #1349114 Sat Mar 07 2020 05:30 AM
Boltergeist
Just make sure the frame is well supported on jack stands and level when you remove the crossmember, and when reinstalling the modified part. You'll also need to fabricate mounting points for the mid-engine mounts and a crossmember for the transmission tail shaft, so the only purpose for the dropped crossmember at the bellhousing area is to prevent frame flexing at the spring mounts. If you're doing a butcher job on the frame to install independent front suspension, the frame is probably going to get distorted anyway, no matter how many precautions you attempt.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Hotrod Lincoln #1349138 Sat Mar 07 2020 02:34 PM
Rocketman: removing and then modifying and then reinstalling that crossmember is certainly doable, however, I’ve attached photos of how I addressed that roadblock. I cut out the center of that crossmember and then fabricated a removable tie-plate of 1/8” steel to straddle that opening. Those are 1/2 inch grade 5 bolts (4 on each side) bolted into 1/2” coupler nuts bolted onto the flange at the bottom of that crossmember. That flange is plenty wide to accommodate the bolts. You can then also adjust the position of the tie-plate as needed to get clearance for the transmission oil pan. Good Luck, Dave
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
Rocket man #1349152 Sat Mar 07 2020 04:56 PM
I'm not a mechanical engineer, but that crossmember connector design does not look to have the kind of support required along the lateral plane.
I am envisioning the bolt heads eventually shearing the metal of the stub end of what is left of the crossmember.
Your 1/8" plate steel should be able to withstand the shear forces inherent to this design, but the original crossmember steel is not as durable as plate steel.
There is a lot of support needed in this area because the spring perches are located in that vicinity.
Personally, I am not so sure that your design will provide that support.
Rocket man #1349156 Sat Mar 07 2020 06:01 PM
52Carl: I appreciate your comments, and granted, my modification is a compromise and not as preferable as the original design, but it has held up for the past 5 years and 5000 miles (I baby my truck). Plus, as you can imagine, removing the transmission is fairly easy (I switched out the 400 Turbo I originally installed in favor of a 4L60). If and when my arrangement fails, I guess I’ll consider further modifications. I just wanted to give Rocketman some ideas. What did you do? Regards, Dave
"Old Blue"
More pix on Flickr
Rocket man #1349192 Sun Mar 08 2020 12:18 AM
Boltergeist
I would have put a couple of 45 degree bends in that plate with some gussets added, or made the stiffener out of 1 1/2" square tubing instead of creating all the stress risers with the bolts and spacers. Of course, I'm accustomed to building frames that survive dirt track racing conditions, where the rule of thumb is "Build it three times a strong as you think it needs to be, and don't be too surprised when it breaks"!
Flatblu4748 #1349215 Sun Mar 08 2020 02:34 AM
I was searching far and wide for the pics of what I did but could not find them. I am pretty sure that I posted them on this site.
Basically what I did was made my cuts in the same place that you did, but I cut them perpendicular to the ground. I welded plate steel drop plates to crosmember stub ends as well as to the ends of the cut out section of the crossmember.
I then drilled two holes in the drop plates for 1/2" bolts for easy installation and removal of center section.
This ended up giving me a 2" drop to clear the transmission. I can drop the oil pan on the transmission without removing the center section and it looks somewhat more like a stock setup and is very rigid.
As long as you continue to baby your truck and keep an eye on where your bolts go through your plate steel and the crossmember stub ends for failure, you should be alright.
Carl
Rocket man #1349255 Sun Mar 08 2020 02:37 PM
I just had a buddy help me out with this. Added (4) 3/8" steel plates with heavy gauge hardware. Allows to slide the engine / trans in easy and simply bolt it back in. Pic attached.
Mike
1952 -3100 with '54 235 Iowa farm truck "Cecil"
1952Cecil #1349262 Sun Mar 08 2020 04:47 PM
52Carl: I was able to find your picture that you referenced in your above explanation. I wanted the other Bolters to appreciate your effort....”a picture is worth a thousand words”. Carl, like you, “I’m not an engineer”, either, and everybody’s got an opinion....I’ll just leave it at that...
"Old Blue"
More pix on Flickr
Rocket man #1349277 Sun Mar 08 2020 08:22 PM
I am a mechanical engineer, for what that's worth. wink
I like Mike's (1952Cecil) solution. Nice and stiff. Although it's not dropped that much.
Carl's has a couple of hinge points that would work better if stiffened up a bit. A couple of gussets from the frame side of the plate up to the original crossmember would help immensely.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Page 1 of 2 1 2
Moderated by  SWEET
