The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (Harold41, Cosmo, DennisM, Bill Marlow, Arne, Forty9, 2 invisible), 224 guests, and 2 robots.
Forums50
Topics122,185
Posts980,146
Members44,168
Most Online1,229
Jan 21st, 2020
Image Posting Policy
235 Camshaft
#1346372 Thu Feb 13 2020 05:16 PM
John L. Offline OP
New in the box camshaft for a 235 small journal. Melling p/n CCS12 100.00 ships on your dime.
Re: 235 Camshaft
John L. #1347295 Thu Feb 20 2020 09:22 PM
Is this for a splash oiler?
Re: 235 Camshaft
John L. #1347296 Thu Feb 20 2020 09:28 PM
ace skiver
Looks like it is listed by Melling for cars: 1942-1953 216 & 1950-1953 216/235?
The listings do not show it for trucks.
The Master Parts Catalog shows that truck and car 216 cams were the same from 1937-1953.
The Master Parts Catalog shows 1941-1953 car and truck mechanical lifter 235 cams being the same (but, different from the 216 cam).
The Powerglide-equipped cars (50-53) had a different cam (and, they had hydraulic lifters).
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: 235 Camshaft
John L. #1347357 Fri Feb 21 2020 03:55 PM
Thanks.
I'm trying to help a friend find a cam. Here's the deal- He's having a custom grind done by Isky, but the core he/they had to start with is bad, so there'll need to be a good one sourced to move forward. The block is a '46 truck 235, BUT it's been machined for insert bearings in the bottom end. I don't know the status of the cam bearings. I need to find that out before anyone spends too much mental energy on it.
Re: 235 Camshaft
John L. #1347474 Sat Feb 22 2020 04:17 PM
Boltergeist
Tim, the 235 cam has flat spots between the lobes to clear the connecting rods, due to the longer stroke on the 235. A small-bearing 235 cam would probably work in a 216, but not the other way around.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: 235 Camshaft
John L. #1348081 Thu Feb 27 2020 03:26 PM
John L. Offline OP
The cam does have small journals
Moderated by  Tiny
