The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (Lightholder's Dad, bwilliams, Phak1, Dragsix, HandyAndy, 1 invisible), 169 guests, and 4 robots.
Forums50
Topics118,888
Posts951,603
Members43,287
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Brake lights stay on
#1347735 Mon Feb 24 2020 02:35 PM
This is one of those "it never ends" threads. I've been driving the '51 in my tag line for a few years without any major "gotchas. It does what a old driver truck should do. With the occasional minor hickup. Well this past weekend after a 30 mile trip to town to buy feed, I backed into the barn, unloaded a few sacks of sweet feed and noticed the brake lights were on. Dang, brake-light switch is bad or the pedal is hanging wrong. Nope, pedal fine and after a quick unhooking of the 3 wires to the switch, lights still on.
What I discovered with the wife watching is that with key on, (brake lights still own) the turn signals do blink. So, that's good.
I can turn the lights off when the key's off by pulling out the 4-way flasher activation tab on the turn signal switch. That's good as well since I don't have to pull the battery cables when the truck's setting.
After giving the wiring a quick look, nothing obvious jumps out as wrong so the plan is in the next few days I'll take the turn signal switch apart and see if I can spot the problem.
Yep, once again, it never ends. Will report what I find and the ultimate solution in the hope that it'll help others.
RonR
1970 340 Duster
1951 Farmall Super A
Re: Brake lights stay on
moparguy #1347746 Mon Feb 24 2020 04:17 PM
Moderator - The Electrical Bay and Rocky Mountain Bolters
Do the brake lights do anything when you press the brake pedal?
Another quality post.
Real Trucks Rattle
moparguy #1347749 Mon Feb 24 2020 04:23 PM
Did you eliminate the brake light switch by disconnecting it?
Ed
moparguy #1347750 Mon Feb 24 2020 04:26 PM
Rusty, No Sir.
Ed, Yes Sir.
1970 340 Duster
moparguy #1347755 Mon Feb 24 2020 04:47 PM
Do you have a 7 wire turn signal switch?
Also you said you disconnected 3 wires to the brake switch. Should only be two wires
Sounds like you might have a bad turn signal switch
moparguy #1347937 Wed Feb 26 2020 01:23 AM
Tackled the turn signal/brake light issue today. After spending a couple hours checking most everything but the flasher and not finding a problem I opened up the turn-signal switch. The attached image shows the wire that had popped loose and was creating all the aforementioned problems. The solution was to solder in a piece of twisted wire (with insulation stripped off) into the hole of the contact and then soldering the broken wire to the new connection. Finished it off with a heat shrink sleeve.
Glad to report, all's good now.
To correct my previous comments and response to questions: On my first look at possible causes for the brake lights staying on I mistakenly (for some impossible to defend reason) mistook the dimmer switch for the brake light switch. I disconnected the three wires to it and of course it had no effect on the brake lights. When I thought through it all while on a walk a day of so later (and with a Homer Simpson forehead slap) I realized what I'd done. When I got back to the shop, I did then unplug one of the brake light switch wires and the brake lights did go off.
RonR
1970 340 Duster
moparguy #1347943 Wed Feb 26 2020 02:06 AM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Thanks for the update.
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Moderated by  Rusty Rod
