The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Getting back to business
First round of holidays is about over. A few weeks before the next ones. For some of us...
Winter is Coming
Time to think about wintering your Bolt.
(continued)
A good Tech Tip
WINTERIZING YOUR TRUCK
including a link back to the Forums for some new thoughts.
Searching the Site
Old Truck Calendars
In the works
2023 Stovebolt Calendars
Check for details!
6 members (coilover, Peggy M, 2-Ton, Justhorsenround, Gray_Ghost, 1 invisible), 192 guests, and 3 robots.
Forums60
Topics127,669
Posts1,046,519
Members46,401
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1346890 Mon Feb 17 2020 08:47 PM
Getting ready to change the oil on my 235 and with all the new stuff out there was wondering what everyone is using. its not driven much but I like to see some oil pressure at idle
59chevy36 #1346895 Mon Feb 17 2020 08:55 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon and HiPo Forum
No synthetic.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
59chevy36 #1346903 Mon Feb 17 2020 09:47 PM
I have been using Brand Penn 10W30 (now called Penn Grade One) for 7 or 8 years now. Real Pennsylvania crude oil base, clings to the parts, especially the rockers over the winter, has a zinc package and a wear package compatible with our old motors, and seems to hold better pressure then the Pennzoil I use to use, at least from what I have experienced.
Mike
59chevy36 #1346906 Mon Feb 17 2020 10:24 PM
Valvoline VR-1 30 weight is what I use. You won't have winter weather to worry about in S. Florida, so 30 weight should be your friend. VR-1 also has extra zinc and holds pressure well in hot climates.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
59chevy36 #1346934 Tue Feb 18 2020 01:52 AM
I use Delo 30w, any of the diesel oils still have enough zinc in them to protect the cam and lifters.
ESum
59chevy36 #1347406 Sat Feb 22 2020 02:18 AM
Thanks for the input. Think I will go with the VR1 oil, like the zinc additive. But it looks to be hard to find in a 30 wt wonderif 10w30 would be ok. and yes we have had a light winter here still haven't put on the tire chains
59chevy36 #1347417 Sat Feb 22 2020 03:03 AM
The VR-1 if it is truly a RACING oil, it won't have detergent, and yes 10w-30 is fine, I can't even believe anyone uses a straight weight oil, even Caterpillar has relented. And if you have a tight engine that doesn't leak a lot of oil, synthetic is more than fine, it is by far a superior lubricant.
brokenhead #1347459 Sat Feb 22 2020 01:57 PM
Is this a reflection on the viscosity of synthetic or the cost of it?
1965 Chevy C10 Longbed Fleetside
(Engine needed, originally 230)
59chevy36 #1347461 Sat Feb 22 2020 02:22 PM
The viscosity is not an index of load capacity, film strength, "slippery-ness", or bearing protection.
It's the thickness: how much can pass through a sized orifice per second at a given temperature. Paint, molten metal, and maple syrup may have the same viscosity.
59chevy36 #1347501 Sat Feb 22 2020 06:48 PM
Yep that's true.
Water works for bearings, but it can't stand the heat in an engine. In fact there are circulating pumps for heating systems that are lubricated by the pumped water.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Page 1 of 2 1 2
