The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (DavidBraley, elhippie64, J Lucas, 69Cuda, Hotrod Lincoln, 1 invisible), 177 guests, and 3 robots.
Forums50
Topics121,070
Posts970,583
Members43,832
Most Online1,229
Jan 21st, 2020
Image Posting Policy
235 Camshaft
#1346372 Thu Feb 13 2020 05:16 PM
John L. Offline OP
New in the box camshaft for a 235 small journal. Melling p/n CCS12 100.00 ships on your dime.
Re: 235 Camshaft
John L. #1347295 Thu Feb 20 2020 09:22 PM
Is this for a splash oiler?
Re: 235 Camshaft
John L. #1347296 Thu Feb 20 2020 09:28 PM
ace skiver
Looks like it is listed by Melling for cars: 1942-1953 216 & 1950-1953 216/235?
The listings do not show it for trucks.
The Master Parts Catalog shows that truck and car 216 cams were the same from 1937-1953.
The Master Parts Catalog shows 1941-1953 car and truck mechanical lifter 235 cams being the same (but, different from the 216 cam).
The Powerglide-equipped cars (50-53) had a different cam (and, they had hydraulic lifters).
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: 235 Camshaft
John L. #1347357 Fri Feb 21 2020 03:55 PM
Thanks.
I'm trying to help a friend find a cam. Here's the deal- He's having a custom grind done by Isky, but the core he/they had to start with is bad, so there'll need to be a good one sourced to move forward. The block is a '46 truck 235, BUT it's been machined for insert bearings in the bottom end. I don't know the status of the cam bearings. I need to find that out before anyone spends too much mental energy on it.
Re: 235 Camshaft
John L. #1347474 Sat Feb 22 2020 04:17 PM
Boltergeist
Tim, the 235 cam has flat spots between the lobes to clear the connecting rods, due to the longer stroke on the 235. A small-bearing 235 cam would probably work in a 216, but not the other way around.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: 235 Camshaft
John L. #1348081 Thu Feb 27 2020 03:26 PM
John L. Offline OP
The cam does have small journals
Moderated by  Tiny
